Transmission oil leaking/Brake problems
Old Apr 11, 2007 | 08:51 PM
baalan's Avatar
Default Transmission oil leaking/Brake problems
Does anyone know why when at high revs Iget what seems to be an oil dump all over my exhaust. It usually happens when I'm on an incline or shifting from 3rd to D at hiway speeds. Could a bad mainseal cause this. Also my brakes seem to have stopped working. I had the booster ckecked and it turned out that I had leaking vacume hoses. These were replaced but the problem still exists. Master cylinder, calipers? Any help would be appreciated as I just spent $2000.00 on a major tune up amd brake fix. It's a 92 100 CS
Old Apr 13, 2007 | 10:42 PM
InExile's Avatar
Default RE: Transmission oil leaking/Brake problems
why in the hell are you shifting leave it in D that is why it is an AUTOMATIC ... and try to bleed the brakes first
Old Apr 14, 2007 | 06:23 PM
baalan's Avatar
The oil problem also happens when the tranny kicks down itselfto pass or whether I shift down manually. The brakes do work but Ihad to apply an enormous amount of pressure to get it to stop. That's why I thought maybe the master. I was driving and it just happened., not gradual.
Old Apr 18, 2007 | 02:23 AM
InExile's Avatar
could be master ... or the hydraulics messed up .... and see if that leaking fluid is not PS fluid .... leaking PS fluid would also cause bad brakes ... check the tranny level by the book
Old Apr 21, 2007 | 01:33 PM
baalan's Avatar
Also when it happened, the pads were worn down to nothing. I replaced the pads and rotors with new.
NYankee
Jun 19, 2012 12:07 PM
mckeenr
Feb 25, 2010 09:46 AM
strickland.j
Feb 11, 2008 11:42 PM
1990AudiV8Quattro
Nov 16, 2006 01:36 AM
JDUB
Jun 22, 2004 01:43 AM
