Upgrading light bulbs
Old Feb 13, 2005 | 10:15 PM
9foraudi's Avatar
Default Upgrading light bulbs
I would like to upgrade the light bulbs on my 1989 200 Turbo with xenon bulbs. Can the existing halogen bulbs be simply replaced with the xenon or is a conversion kit required for this upgrade? I have seen xenon bulbs listed for as low as $9.95 to $19.95 for each bulb. The cheaper bulbs are made in Korea while the more expensive bulbs are made in Germany. What are the better brands of light bulbs and what should I look for in a xenon light bulb?
Rob F.
Old Feb 14, 2005 | 02:25 AM
Jestnomen's Avatar
6th Gear
Default RE: Upgrading light bulbs
If you are just looking for a "bluish" xenon bulb then go for it. A true xenon system is a kit which includes, ballasts, ignitors and the light bulb capsule. The bulbs you are referring to are just halogen bulbs with a tiny amount of xenon gas. They are a gimmick and offer no benifit to traditional halogen bulbs. A true xenon system or often referred to as HID (high intensity discharge) will cost over 200 dollars.
Old Feb 15, 2005 | 11:54 PM
9foraudi's Avatar
I suspected that a conversion kit would be required for true xenon lighting. Thanks for the confirmation.
Old Feb 18, 2005 | 07:52 AM
sadik's Avatar
Those so called "xeno lights" are not xenon.. they are blue lights with higher candel power. Which is ilegal in way... I use to have these on my Path and they burned out my wiring... Actualy melted the plastic conected, a huge mess...
I you want to you these, then I adivse creating a wiring system your selft with 2 realys and direct connection to battery.. This is easy and not as expesive..
numlock4045
Feb 9, 2011 07:12 AM
generik777
Jun 6, 2008 10:36 PM
dkazimee
Jan 19, 2008 11:35 AM
wanteda4
Jan 9, 2008 01:32 AM
SMoLiK
Dec 12, 2006 06:38 AM
