Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
2001 Allroad 2.7t O2 sensors..
Old Oct 2, 2011 | 08:33 AM
big_nige's Avatar
Default 2001 Allroad 2.7t O2 sensors..
Every few hundred miles i get the engine light up, i reset the code P0130 & sometimes P0150 (left & right o2 sensors) I reset it with my reader & it's ok again for a while.
Any ideas if it's likely to be a sensor or something more expensive?
Old Oct 2, 2011 | 09:20 AM
02A6Beau's Avatar
there are four oxygen sensors in the 2.7T common wisdom is if you need to replace one, you should replace all. ~$100 US, each. Intermittent problems like you describe are usually a sign that the sensors are starting to go bad or you have an exhaust leak.
good luck
Old Oct 2, 2011 | 09:35 AM
big_nige's Avatar
Four! sounds about right, i can get them for about £30 ukp each, so not too bad. Car drives 100% fine, no issues..
Well, not with the engine, apart from oil leaks.
Old Oct 2, 2011 | 05:26 PM
02A6Beau's Avatar
sound like your car and my car could be twins (or at least related)
your car talks funny though...
all stuff I plan on taking care of, valve cover gaskets for the oil leaks and O2 sensors...eventually. as soon as I get the money/motivation/time...meantime as long as it gets me from A to B I will keep adding oil as needed and ignoring the CEL
Old Oct 3, 2011 | 11:18 AM
big_nige's Avatar
Yep!!
cliffordselover
Nov 25, 2013 05:15 PM
HWY HNTR
Oct 4, 2010 02:42 PM
michallroad
Apr 21, 2010 10:54 PM
cmkarabinos
Sep 18, 2007 11:40 AM
tufelkinder
Mar 29, 2007 06:26 PM
