Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
4.2 Starting problem
Old Dec 31, 2012 | 02:12 PM
hprd's Avatar
Default 4.2 Starting problem
I have an intermittent starting problem with my 04 allroad with the 4.2 engine and it has about 150k miles on it now.
The problem I am having, is that after sitting for a while, the car will not start right away. If I cycle the key repeatedly, it it will eventually start. Or, if I walk away and come back 10-15 minutes later, it will fire absolutely perfectly. This problem seems to be worse when it is cold. Once it has fired up, it starts absolutely perfectly from that moment on, until it sits for at least a few hours or more.
When I turn the key, the dash lights up, everything responds completely normally, but there is no click, no whine, no nothing when I turn the key to the start position. There is a very slight drop in the voltmeter when the key is in the start and it isn't responding.
It seems as though something is not working to allow power to the starter so there is no response from the starter. Is there a sensor that has to open the pathway for power to the starter that may not be working?
Last year, I was having starting problems. I replaced the ignition switch and problem solved. This year, when the problem started, I assumed the ig switch was just going to be a yearly replacement. Got it replaced at the same time I replaced the fuel pump. Did not solve the problem though.
I am faced with taking a guess and replacing the starter to the tune of a grand or so. I really don't want to do that if it truly isn't the starter obviously.
Recommendations, past experiences etc would be GREATLY APPRECIATED.
Thanks.
Lourenstien
Oct 30, 2012 07:49 PM
bradwall96
Apr 25, 2011 05:10 PM
PaulA4
Feb 20, 2007 06:55 PM
lhayes
Jun 30, 2006 09:20 AM
PaulA4
Mar 9, 2006 04:30 PM
