Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Service at 90.000 km.
Old Jan 29, 2009 | 05:01 AM
gianton's Avatar
Default Service at 90.000 km.
Hello,
My A6 Allroad 3.0 TDI '06 Tiptronic is near to the 90.000 km service.
Could anyone please advise what parts need to be changed?
Any inputs highly appreciated!
Old Jan 29, 2009 | 08:55 AM
swilky2000's Avatar
Found at www.allroadfaq.com
At 60,000 Mi (96,000 Km)
Engine Oil – Change the oil. ·
Engine Oil Filter – Replace the oil filter. ·
Engine – Check for leaks. ·
Cooling System – Check the coolant level. Add coolant if necessary. ·
Exhaust System – Check for damage and leaks. ·
Engine, On-Board Diagnostic – Check Diagnostic Trouble Code Memory. Purge if necessary,
where applicable. ·
Doors – Lubricate door hinge mechanism. ·
Battery – Check electrolyte level. Add if necessary ·
Windshield Wiper and Washer – Check fluid level. Add fluid if necessary.
Automatic Shift Lock (ASL) – Check operation, including park/neutral position switch, where
applicable. · ·
Manual Transmission – Check gearshift mechanism and clutch for proper interlock operation. ·
Tires and Spare Wheel – Check for wear and damage. Check the pressure.
Service Reminder Indicator Display – Reset the display. ·
Brake system – Check for damage and leaks. Check thickness of pads and brake fluid level.* ·
Drive Shafts – Check the boots. ·
Road Test – Check braking, kick-down, steering, electrical, heating and ventilation systems, air
conditioning and power accessories. · · · ·
Lights – Check the lights. · · · ·
Front Axle – Check dust seals on ball joints and tie rod ends. Check tie rods. · · · ·
Automatic Transmission – Check for leaks.
Manual Transmission – Check for leaks.
Manual Transmission Final Drive – Check oil level. Add oil if necessary.
Dust and Pollen Filter – Replace filter. ·
Headlights – Inspect headlights. Adjust if necessary. ·
Sliding Roof – Clean guide rails and lubricate with grease spray.
Jedward02
Feb 4, 2009 10:30 AM
DarkHelmet
Jul 24, 2004 09:46 PM
