Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Spacer for stock wheels
Old Apr 27, 2011 | 12:37 PM
vtraudt's Avatar
Default Spacer for stock wheels
To bring the edge of the tires (edge=end of tread, rounding into the side) flush with the fender extensions, I want to use spacers on the stock wheels.
This setup has been proven to provide (IMO!) the best stance (followed this guideline on various cars, including A4 which sits 'perfect').
How much can be added with 'spacers + extended bolts', and when are 'adapters' (bolt to the hub, wheels bolt to adapter) needed?
I haven't measured yet (does anyone have the dimension?) how much 'space' I need.
Old Jun 5, 2011 | 12:59 AM
Zachariah's Avatar
20mm spacers with 48mm bolts should do the trick....
Old Jun 5, 2011 | 09:40 AM
vtraudt's Avatar
I installed for my stock Allroad double spoke wheels:
20mm hubcentric spacers, 45mm bolts front (worked, no rubbing)
20mm hubcentric spacers, 50mm bolts rear: bolts to long, locking wheel. Ground down to ca. 47mm. Worked, no rubbing.
Result: tire sidewalls not entirely flush with fender edge (probably another 5mm?), but it allows me run a bit lower since the tire edge still tucks inside the fender. If fully flush, it would likely rub on the fender at the current lowered setting.
Old Jun 6, 2011 | 09:19 AM
Zachariah's Avatar
Default Looks Good!
Excellent. Now, get some cheap ECS mudflaps, to complete the wide stance look!
HockeyA6
Apr 4, 2014 07:10 PM
bigatstyle
Nov 9, 2012 08:29 AM
DerrickS
Nov 15, 2008 11:48 AM
ltsheets
Apr 24, 2008 07:16 AM
n0dn4rb
Jan 26, 2007 02:31 AM
