Tiptronic top gear
Alright folks, I know that the cost would probably make such a thing prohibitive but is there a way to change the gear ratio (either the final drive from the transmission or the fifth gear cog) so that the engine RPM would be more like 2200-2300 at 70 rather than 3000? It's not a dragster anyway but it seems the mileage would improve and the engine would last longer if it reved lower. Any thoughts?
VAGCOM
Radio56-Adaption10-Channel1
56-10-1
{Tire Circumference Table}
Summer Tires
1790 - 145/80 R14
1815 - 165/65 R15
1803 - 175/60 R15
1806 - 185/50 R15
1935 - 195/65 R15
1910 - 205/60 R15
1930 - 205/55 R16
1818 - 205/40 ZR17
1960 - 215/55 R16
2060 - 225/60 R16
1930 - 225/45 R17
2074 - 225/55 R17
1943 - 225/40 ZR18
1960 - 235/50 R16
1964 - 235/45 R17
1967 - 235/40 ZR18
2065 - 245/45 R18
2065 - 245/45 ZR18
1940 - 255/40 R17
1937 - 255/35 R18
1937 - 255/35 ZR18
2016 - 255/40 ZR18
2016 - 255/35 ZR19
2092 - 255/35 ZR20
Winter Tires
1775 - 155/65 R15
1895 - 185/65 R15
1935 - 195/65 R15
1930 - 205/55 R16
1960 - 215/55 R16
2092 - 215/65 R16
2060 - 225/60 R16
1930 - 225/45 R17
2070 - 225/55 R17
1940 - 225/40 R18
2010 - 225/45 R18
2040 - 235/45 R18
2114 - 235/50 R18
1940 - 255/40 R17
See http://en.openobd.org/audi/rns.htm#tires
56-10-1
Summer Tires
1790 - 145/80 R14
1815 - 165/65 R15
1803 - 175/60 R15
1806 - 185/50 R15
1935 - 195/65 R15
1910 - 205/60 R15
1930 - 205/55 R16
1818 - 205/40 ZR17
1960 - 215/55 R16
2060 - 225/60 R16
1930 - 225/45 R17
2074 - 225/55 R17
1943 - 225/40 ZR18
1960 - 235/50 R16
1964 - 235/45 R17
1967 - 235/40 ZR18
2065 - 245/45 R18
2065 - 245/45 ZR18
1940 - 255/40 R17
1937 - 255/35 R18
1937 - 255/35 ZR18
2016 - 255/40 ZR18
2016 - 255/35 ZR19
2092 - 255/35 ZR20
Winter Tires
1775 - 155/65 R15
1895 - 185/65 R15
1935 - 195/65 R15
1930 - 205/55 R16
1960 - 215/55 R16
2092 - 215/65 R16
2060 - 225/60 R16
1930 - 225/45 R17
2070 - 225/55 R17
1940 - 225/40 R18
2010 - 225/45 R18
2040 - 235/45 R18
2114 - 235/50 R18
1940 - 255/40 R17
If you compare spec's of the 4.2 allroad tip to a 4.2 S6 tip you will see that the final drive gear ratio's are 3.908:1 for the allroad compared to 2.727 :1 for the S6. thats a huge differance. Can the allroad tranny be modified to the S6 final drive ratio?
Taller tires changes a lot of other things though. Looking at the list it appears that the other 17" tires 235/45 and 255/40 have circumferences of 1964 and 1940 respectively. I don't feel like buying new rims, I like the ones I have. I might be reading the chart wrong but it looks like the wider 17" tires are actually shorter?? Also, how large a tire fits before things start to rub? Thanks guys.
