vibration, through steering wheel
Tires could be worn, wheel could be out of balance, upper and lower tie-rod ends could be going out, wheel bearing (is there any play in the wheel when you rock it side to side with your hands at the 9 o'clock and 3 o'clock position or the 12 and 6 position). Those are just some things to look for. Rotate your tires if you can't visually find anything wrong and see if you get the vibration.
