Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Warning Lights (ABS, Suspension, Traction Control)
Old Feb 18, 2008 | 10:36 AM
vc1492a's Avatar
Default Warning Lights (ABS, Suspension, Traction Control)
Ive recently started getting this weird combination of warning sensor lights from my allroad, only happens about 1/10 times I start the car. The ABS, Air Suspension, and Traction Control lights all come on. Car didnt behave any differently. I took it to the dealer and they said it was a faulty brake sensor, and it was fixed. But im still not convinced. Any Ideas? Could it be the Quattro?
Here's a Pic: http://i31.tinypic.com/mrd2mq.jpg
Thanks
Old Feb 19, 2008 | 12:38 PM
funpig's Avatar
Member
Default RE: Warning Lights (ABS, Suspension, Traction Control)
I've seen this in the past a couple of times over the years. Typically occurs for me after having driven through deepish water, then braked on a rutted surface. No change in the vehicle other than the lights. My guess is that it is a temporary sensor problem and I have chosen to ignore.
Old Feb 19, 2008 | 01:11 PM
techbod's Avatar
^ totally agree - the problem is ABS sensors getting clogged with mud common on off road conditions so a good jet wash is recommended on the underside (ABS/TRACTION/HIGHT Control ) are all linked in the ECU so probably loss of traction could cause all of the issues, clean it/clear the codes and see how it goes ( and post the fault codes )
Old Feb 19, 2008 | 08:41 PM
incrementalg's Avatar
I had the same thing happen onceafter driving in somewet and muddy conditions.Car drove normally andit went away as soon as I turned the car off and started again.Dealer said the same thing...it was a clogged or dirty sensor.
Old Feb 20, 2008 | 11:22 PM
vc1492a's Avatar
oh ok guys thanks
Old Jul 14, 2008 | 09:06 AM
pixelpeon's Avatar
I'm getting the "Break Light Error" problem - similar to the above. Each time I am pressing break, the light goes on. Did pluging to the VAG, cleared error code, do the washing :-)...but the problem persists. Any ideas how much is the replacement service for this particular sensor?
Old Jul 14, 2008 | 11:39 AM
cjh137's Avatar
Hey there, I am new to Audi and my Allroad. I was wondering what the mod was that you lave listed as "20 mm spacers"? Thanks.
Good luck with your sensor and warning light issue, I hope it is as simple as a good wash to fix it.
Old Jul 14, 2008 | 12:55 PM
cjh137's Avatar
ORIGINAL: cjh137
Searched it....found it...never mind me.
Old Aug 2, 2008 | 06:00 PM
Viking Queen's Avatar
Default I had the same issue
All three of those lights came on. At the dealer's, they said it was a blown fuse.
I plugged in my camper, and it happened again. The wiring harness was causing a short of some sort. Took it to another repair place and again, it was a blown fuse.
Also purchased a new wiring harness /adapter (that one ended up catching on fire, less than a year after I purchased it new from an Audi dealer).
It is a 2003 AR 2.7T. Great car, but that was an interesting experience.
Old Aug 3, 2008 | 04:37 AM
MYD WGN's Avatar
Coud be a brake light switch
