Part-Out: S4 2.7T Engine
I have a 2.7T engine out of my 01 S4 I have slowly been parting out. If you need anything off of the motor please let me know. It has 113k on it. Everything is available off of it. Please let me know!!
--Eric
PARTS SOLD OFF ENGINE:::
K&N FILTER
TIMING BELT COVERS
N75 VALVE
J BOX ECU
ALL FOUR O2 SENSORS
AIRBOX
AIRBOX TO RADIATOR SUPPORT PLASTIC PCS (2)
COIL PACKS
MAF SENSOR AND HOUSING
MAP SENSOR
EGT SENSORS
FAN CLUTCH AND PULLEY
MAF PIGTAIL
SNUB MOUNT
SERP BELT
STRATMOSPHERE DIVERTER VALVES
POWER STEERING PUMP, BRACKET, AND HARDWARE
ALTERNATOR
VALVE COVERS
IGNITION CONTROL MODULES
INTAKE MANIFOLD
MOTOR MOUNTS (FRONT PAIR)
K03 TURBOS
FUEL RAIL
ENGINE COVER SET (6 PCS)
OIL PAN SET (UPPER AND LOWER)
--Eric
K&N FILTER
TIMING BELT COVERS
N75 VALVE
J BOX ECU
ALL FOUR O2 SENSORS
AIRBOX
COIL PACKS
MAP SENSOR
EGT SENSORS
MAF PIGTAIL
SNUB MOUNT
SERP BELT
ALTERNATOR
VALVE COVERS
INTAKE MANIFOLD
K03 TURBOS
FUEL RAIL
