Part-Out: 2001 S4 Black Auto
Old Apr 6, 2011 | 01:05 PM
01s42.7t's Avatar
Default Part-Out: 2001 S4 Black Auto
I have an S4 I am looking to part out. It has black exterior and the interior is black with grey alcantara inserts.
Let me know what you are looking for and I will get back to you as far as pricing, shipping, and everything else.
I am located near Atlanta GA and I will be updating this with parts as I sell them.
--Eric
ITEMS SOLD::::
INTERIOR ALUMINUM BELTLINE TRIM
DRIVERS SIDE FENDER
PASSENGER SIDE FENDER
DRIVERS FRONT BOSE DOOR SPEAKER
PASSENGER FRONT BOSE DOOR SPEAKER
SIDE SKIRTS
BLACK FELT WEATHERSTRIPPING
SKID PLATE
SUN VISOR CLIPS
REAR BRAKE SETUP (PADS/CALIPERS/CARRIERS/LINES/ROTORS/HARDWARE)
VANITY LIGHTS ON HEADLINER (UNDER SUN VISORS)
DRIVERS SIDE REAR DOOR
DRIVERS SIDE FRONT DOOR
PASSENGER TAIL LIGHT
MIRROR GLASS
FRONT BUMPER
REAR ABS SENSOR
ARM REST LID
HID'S AND BALLASTS
HEADLIGHT SQUIRTERS / COVERS
CENTRAL LOCKING PUMP
WARNING TRIANGLE
CARGO NET
BATTERY COVER
IN-DASH CUP HOLDER
DRIVERS SIDE FRONT SEAT BELT
OH S*** HANDLES
SUNVISORS
SUNROOF CONTROL / MAP LIGHT
HOOD
S4 GRILLE
HOOD STRUT
PASSENGER SIDE HEADLIGHT
PASSENGER SIDE INTERCOOLER
K&N FILTER
REAR DECK BOSE SPEAKER
HVAC CONTROLS
RADIATOR CORE SUPPORT
INTERCOOLER SHROUDS
DRIVERS / PASSENGERS FRONT INNER FENDER LINERS
TIMING BELT COVERS
TRIM ON TOP OF STEERING COLUMN
ALUMINUM PLATES UNDER CAR
SYMPHONY RADIO
TCU
N75 VALVE
J BOX ECU
FRONT BRAKE SETUP (PADS/CALIPERS/CARRIERS/LINES/ROTORS/HARDWARE)
MIRROR CAPS
ANTENNA DIVERSITY BOX
HAZARD TRIM
CIGARETTE LIGHTER ASSEMBLY
ASHTRAY
CD CHANGER COMPLETE W/ MOUNTING BRACKET
AUTO DIM REAR VIEW MIRROR
GAS CAP
WIPER BLADES
GAUGE CLUSTER
REAR MAP LIGHT CLUSTER
STEERING WHEEL W/ AIRBAG
AC CONDENSER FAN
CENTER VISOR
AIR BAG MODULE
OWNERS MANUAL
AIR BAG CLIPS
PASSENGER FRONT POWER WINDOW MOTOR
PASSENGER REAR POWER WINDOW MOTOR
PASSENGER FRONT WINDOW REGULATOR
TIPTRONIC CIRCUIT BOARD
CHROME TIPTRONIC SHIFTER SURROUND
REAR BUMPER
ALL FOUR O2 SENSORS
FLOOR MATS
AIRBOX
AIRBOX TO RADIATOR SUPPORT PLASTIC PCS (2)
FILLER PLATE
COIL PACKS
WHEELS AND TIRES
CENTER VENTS X 3
MAF SENSOR AND HOUSING
B-PILLAR COVERS
C-PILLAR COVERS
MAP SENSOR
REAR SEAT BELT SET
EGT SENSORS
FAN CLUTCH AND PULLEY
SNUB MOUNT
SERP BELT
CLUSTER PIG TAILS
FOG LIGHTS
DRIVERS SIDE AXLE SHIELD
COMPLETE FUEL PUMP
FRONT BUMPER BRACKETS
SNUB MOUNT
SERP BELT
CABIN MOTION SENSOR
POWER / HEATED / AIRBAG PIGTAILS FOR DRIVER & PASSENGER SEATS
SUNROOF SLIDE COVER
SPORT INTERIOR DOOR CARDS
SPORT INTERIOR BLACK LEATHER W/ GREY ALCANTARA INSERTS
WASHER FLUID BOTTLE
HOOD WEATHERSTRIPPING
HEADLINER
STRATMOSPHERE DIVERTER VALVES
POWER STEERING PUMP, BRACKET, AND HARDWARE
HAZARD SWITCH / RELAY
PASSENGER FRONT ABS SENSOR
E-BRAKE CABLES
TURN SIGNAL PIGTAILS
FOG LIGHT PIGTAILS
FRONT SWAY BAR
REAR SWAY BAR
BRAKE BOOSTER / BRAKE MASTER CYLINDER / BRAKE RES
FUEL DOOR
SIDEMARKERS
LICENSE PLATE LIGHT BAR
POWER STEERING COOL LINE
REAR S4 BADGE OFF OF TRUNK
FRONT LOWER SPRING PERCHES
A/C LINES UNDER ENGINE
APR BI-PIPE
ARM REST BASE
STEERING COLUMN COVER
FULL SET OF LUG BOLTS
ELECTRIC RADIATOR FAN
CAT-BACK EXHAUST
FRONT SHOCKS
FRONT SPRINGS
POWER STEERING HOSE
PASSENGER SIDE AIR VENT
ABS MODULE (PUMP & CONTROL)
RADIATOR
FUEL PRESSURE REGULATOR
ALTERNATOR
OEM JACK KIT
SPARE TIRE HOLD DOWN
TRUNK LID
TIPTRONIC DOWNPIPES
VALVE COVERS
CARPET
DRIVERS SIDE SUBFRAME MOUNT
AC CONDENSER
HORN SET W/ PIGTAILS
DRIVER SIDE INTERCOOLER
DRIVER SIDE TURBO OIL RETURN LINE
POWER STEERING RACK
MIRROR BASES / MOUNTS
TURBO MANIFOLDS
REAR SHOCK MOUNTS
COMBINATION SWITCH
DRIVERS SIDE TAIL LIGHT
COMPLETE FRONT WIPER ASSEMBLY
C-PILLAR PLASTIC PIECES AROUND WINDOWS
IGNITION CONTROL MODULES
PASSENGER FRONT DOOR
HEATER CONTROL VALVE
INTAKE MANIFOLD
MOTOR MOUNTS (FRONT PAIR)
PASSENGER SIDE SEAT BELT
KEY FOB
K03 TURBOS
RAIN TRAY W/ WEATHERSTRIPPING
REAR SUBFRAME
BOSE AMP
DRIVER SIDE FRONT STEEL UPRIGHT
TRUNK STRUTS
FIRST AID KIT
FUEL RAIL
SECONDARY AIR PUMP
Y-PIPE
DRIVERS SIDE HEADLIGHT
REAR STRUTS
REAR DOOR BOSE SPEAKERS
ENGINE COVER SET (6 PCS)
OIL PAN SET (UPPER AND LOWER)
REAR DIFFERENTIAL
Old Apr 15, 2011 | 10:18 AM
junkeravant's Avatar
Default This post confusing?
You list parts that have sold....what is left? What did the front bumper go for?
Old Apr 15, 2011 | 10:38 AM
01s42.7t's Avatar
if it's on the list it's sold and gone.
Old Apr 15, 2011 | 10:56 AM
richy's Avatar
don't think i saw it on the list but do you still have the front lip/spoiler/valence?
Old Apr 15, 2011 | 12:57 PM
01s42.7t's Avatar
junkeravant - it started out as a complete car. if it's on the list it's gone if it isn't on the list then i still have it available. everytime something sells i will update the list. if you need something that is not on the list please let me know and i can get you prices and pics.
richy - complete front bumper was sold.
Old Apr 21, 2011 | 08:35 AM
01s42.7t's Avatar
anybody need anything? still have plenty of parts available. if it's on the list above it has been sold. thanks!
Old Apr 21, 2011 | 03:17 PM
bkosonen's Avatar
Do you have the MAP/Boost Sensor on the throttle body?
Old Apr 21, 2011 | 03:30 PM
01s42.7t's Avatar
pm'ed - bkosonen
Old Apr 23, 2011 | 02:38 PM
Lear70's Avatar
I need the connector in between the wiring harness and the passenger side front turn signal. There's a plastic connector in between the wire harness and the bulb (why is beyond me, but it's there and the dealer wants like $30 bucks).
I see you sold the carpet mats... bummer. Did you also sell the power steering pump and/or rack and pinion? I have a power steering problem and don't know which it is yet, will have to troubleshoot more but will likely need one or the other.
Thanks!
Old Apr 23, 2011 | 09:52 PM
austinw2000's Avatar
S4 Cluster with Pigtail of harness? Mileage?
Headlight harness pigtail?
