AudiForums.com
-   Archive - Interior/Electrical/Stereo (https://www.audiforums.com/forum/archive-interior-electrical-stereo-64/)
-   -   Adding Subs to a factory b5 bose amp help? (https://www.audiforums.com/forum/archive-interior-electrical-stereo-64/adding-subs-factory-b5-bose-amp-help-188521/)
carmichael1620 Oct 21, 2012 10:17 PM
I am trying to figure out the best way to add an amp and subs to my factory bose system i tried tapping into my leads going to the factory amp but i cant seem to get anything to work. If you know anything about doing this i would appreciate some advice.
BlueA4 Nov 10, 2012 05:41 AM
Your answer will vary depending on whether you have Bose or not, a sedan or an Avant.
kcantor Jan 5, 2013 11:10 PM
I saw a diagram on here once where it shows you step by step on how connect aftermarker amps n sub, search it on here
xfsasx Apr 6, 2013 09:51 AM
I have a c5 a6 with the bose amp and stock subwoofer, i installed a 15' single sub and a 1600 watt amp a couple years ago and has been working great since... i pulled power and ground as normal but i pulled remote from the plug on the factory amp and L and R channels from there as well, i just googled for a bose pin out and went from there... I got one of those wire to RCA converters and some wire splicers. It's a bit of a pain in the ass to get the splicers on cause the wires are tightly strung and there's not a ton of slack but a little patience and it'll go great! Good Luck! Hope I helped
