Adding Subs to a factory b5 bose amp help?
Old Oct 21, 2012 | 10:17 PM
carmichael1620's Avatar
Default Adding Subs to a factory b5 bose amp help?
I am trying to figure out the best way to add an amp and subs to my factory bose system i tried tapping into my leads going to the factory amp but i cant seem to get anything to work. If you know anything about doing this i would appreciate some advice.
Old Nov 10, 2012 | 05:41 AM
BlueA4's Avatar
Your answer will vary depending on whether you have Bose or not, a sedan or an Avant.
Old Jan 5, 2013 | 11:10 PM
kcantor's Avatar
I saw a diagram on here once where it shows you step by step on how connect aftermarker amps n sub, search it on here
Old Apr 6, 2013 | 09:51 AM
xfsasx's Avatar
I have a c5 a6 with the bose amp and stock subwoofer, i installed a 15' single sub and a 1600 watt amp a couple years ago and has been working great since... i pulled power and ground as normal but i pulled remote from the plug on the factory amp and L and R channels from there as well, i just googled for a bose pin out and went from there... I got one of those wire to RCA converters and some wire splicers. It's a bit of a pain in the *** to get the splicers on cause the wires are tightly strung and there's not a ton of slack but a little patience and it'll go great! Good Luck! Hope I helped
mkodra
B7 Models
Feb 5, 2012 05:50 PM
axis45
Feb 23, 2009 02:46 PM
Santa Ana Slim
B7 Models
Oct 14, 2008 07:16 PM
jfa_16
Aug 1, 2005 05:15 AM
