WTB 98 a4 instrument cluster, with connectors .
Subscribe
Mar 29, 2012 | 11:18 AM
when i bought my 98 a4 2.8 quattro it came with an s4 instrument cluster but one of the connectors was actually cut off. Have no idea why but it was. so im just looking for a 98 a4 2.8 quattro instrument cluster with the connectors that come from the car. thanks any help is greatly appreciated.
Apr 30, 2012 | 09:01 AM
I have one off a 00, not sure if they are the same, do some research and hit me up if they are...
May 1, 2012 | 07:37 AM
the connector is cut because a 2000 cluster won't fit in a 98 without a good deal of work. I have a 98 cluster, but i need some more info from you
does your wiper stalk have buttons on the end of it with arrows on them
if you remove the cluster is there a center connector in there? it should be either small and black or big and red.
May 1, 2012 | 09:37 AM
Quote: the connector is cut because a 2000 cluster won't fit in a 98 without a good deal of work. I have a 98 cluster, but i need some more info from you
On the windshield stalk there are buttons with up and down arrows... On the connector ill check in a couple hours when I get back home. Ill try to post a picture.. Thanks for the help man, appreciate it
May 1, 2012 | 02:53 PM
for jonbonesjones
so this what the connectors look like, i believe the one you are talking about is the one that is cut off. That one is clearly the middle one. so i wouldnt know what color it was. On the cluster it has on now the middle one is a big gray one which doesnt match the black or red you had mentioned earlier so definitely cut for that reason. Let me know if you have a match, once again appreciate it.
WTB 98 a4 instrument cluster, with connectors .-img_20120501_131735.jpg   WTB 98 a4 instrument cluster, with connectors .-img_20120501_134049.jpg
May 3, 2012 | 07:24 AM
with the amount of wires it looks ilke a red one, have what you need, ill run and get the connector today. how good are you with wiring?
May 3, 2012 | 08:36 AM
Quote: with the amount of wires it looks ilke a red one, have what you need, ill run and get the connector today. how good are you with wiring?
Ok well ill take it! Do you have the cluster as well? About the wiring do you mean actually putting them together? Or with the voltmeter? I'm ok I guess
May 3, 2012 | 11:54 AM
i have a complete 98 cluster with harness if you are still looking for one.
May 3, 2012 | 10:40 PM
Quote: Ok well ill take it! Do you have the cluster as well? About the wiring do you mean actually putting them together? Or with the voltmeter? I'm ok I guess
i have both center connector and the cluster. and its just splicing you will be fine wrap and solder and tape PM me
Jun 17, 2017 | 02:15 PM
HI Guys, If someone looking for latest 2017 Audi model then go through DSR Leasing once. I also buy my car from them at leasing after comparing the others leasing offers. https://dsrleasing.com/car-listings/...m-plus-579-mo/
Subscribe
