Archive - Want to Buy Looking for someone to buy from a vendor or a private owner?
WTB 98 a4 instrument cluster, with connectors .
Old Mar 29, 2012 | 11:18 AM
elye1231's Avatar
Default WTB 98 a4 instrument cluster, with connectors .
when i bought my 98 a4 2.8 quattro it came with an s4 instrument cluster but one of the connectors was actually cut off. Have no idea why but it was. so im just looking for a 98 a4 2.8 quattro instrument cluster with the connectors that come from the car. thanks any help is greatly appreciated.
Old Apr 30, 2012 | 09:01 AM
J_PEZ's Avatar
I have one off a 00, not sure if they are the same, do some research and hit me up if they are...
Old May 1, 2012 | 07:37 AM
jonbonesjones's Avatar
Moderator
the connector is cut because a 2000 cluster won't fit in a 98 without a good deal of work. I have a 98 cluster, but i need some more info from you
does your wiper stalk have buttons on the end of it with arrows on them
if you remove the cluster is there a center connector in there? it should be either small and black or big and red.
Old May 1, 2012 | 09:37 AM
elye1231's Avatar
On the windshield stalk there are buttons with up and down arrows... On the connector ill check in a couple hours when I get back home. Ill try to post a picture.. Thanks for the help man, appreciate it
Old May 1, 2012 | 02:53 PM
elye1231's Avatar
Default for jonbonesjones
so this what the connectors look like, i believe the one you are talking about is the one that is cut off. That one is clearly the middle one. so i wouldnt know what color it was. On the cluster it has on now the middle one is a big gray one which doesnt match the black or red you had mentioned earlier so definitely cut for that reason. Let me know if you have a match, once again appreciate it.
Attached Thumbnails WTB 98 a4 instrument cluster, with connectors .-img_20120501_131735.jpg   WTB 98 a4 instrument cluster, with connectors .-img_20120501_134049.jpg
Old May 3, 2012 | 07:24 AM
Moderator
with the amount of wires it looks ilke a red one, have what you need, ill run and get the connector today. how good are you with wiring?
Old May 3, 2012 | 08:36 AM
elye1231's Avatar
Ok well ill take it! Do you have the cluster as well? About the wiring do you mean actually putting them together? Or with the voltmeter? I'm ok I guess
Old May 3, 2012 | 11:54 AM
a.walker727's Avatar
i have a complete 98 cluster with harness if you are still looking for one.
Old May 3, 2012 | 10:40 PM
Moderator
i have both center connector and the cluster. and its just splicing you will be fine wrap and solder and tape PM me
Old Jun 17, 2017 | 02:15 PM
tanisha's Avatar
HI Guys, If someone looking for latest 2017 Audi model then go through DSR Leasing once. I also buy my car from them at leasing after comparing the others leasing offers. https://dsrleasing.com/car-listings/...m-plus-579-mo/
trumski
Jan 21, 2014 12:40 PM
gkeough
Feb 25, 2012 08:33 PM
asutherland
Jan 22, 2010 09:58 AM
neomaxddr
Mar 17, 2009 10:14 PM
Rickna
May 9, 2008 05:02 PM
