Audi A2 This compact Audi A2 offers a lightweight aluminum structure which allows the small yet efficient engine to offer performance comparable to others in its class.
Headlamp bulb replacement
Old Jul 26, 2006 | 03:50 PM
unixy's Avatar
Default Headlamp bulb replacement
Hi all,
Does anyone know the proceedure for replacing a headlamp bulb on a 2002 A2 ? Not a chance im going to the dealer to get it done!
Thanks in advance
Old Jul 26, 2006 | 04:07 PM
techbod's Avatar
Default RE: Headlamp bulb replacement
its changed from inside the wheel arch there is a little cover there
Old Sep 5, 2006 | 08:13 AM
victormeldrew's Avatar
That's strange, I've replaced mine and never used a cover in the wheelarch.
[ul][*] Remove the "bonnet" and put it somewhere safe. (To remove the bonnet, open the service cover and twist the two black catches, then lift the bonnet forward and off, carefully)[*] Unscrew the headlamp unit using a Torq bit; two Torq screws to undo. One very plainly visible on top, the other one matches it, but is buried a little. Seek and ye shall find![*] Pull the headlamp unit forward, and you will have access to the bulbs. You can disconnect the wiring and pull the unit out completely if you must.[*] Assembly is (as ever) the reverse of removal!
[/ul]
Since the bulbs appear to last 6,00 miles if you're lucky (on the 1.4 TDi at least) you WILL become adept at this procedure!
fullthrottle100
Jan 15, 2012 12:36 PM
sp2208
B7 Models
Mar 7, 2011 07:59 PM
impswin
Dec 20, 2009 05:54 PM
ffdsmokeeater
Aug 29, 2008 10:22 AM
Greyster
Nov 26, 2007 12:51 AM
