Headlamp replacement
Old Jul 24, 2010 | 08:23 PM
sp2208's Avatar
Default Headlamp replacement
2006 a4 s-line. I'm getting a "defective headlamp" warning on my display. I've never replaced this part before. Any suggestions on how to do this and what type of bulb to use?
Old Jul 25, 2010 | 01:21 PM
makav3li's Avatar
headlights are h7 type lights, you can pretty much go to walmart or autozone and theyll have them. Its really not hard, just open up the back of the housing, diconnect the lightbulb and pull it out, itll take a little force. In the inner lights are the highbeams and the outward ones are the low beams lol i made that mistake.
Old Jul 25, 2010 | 04:19 PM
sp2208's Avatar
Can the "h7" bulb be used for both high & low beams? Also, is there any chance to upgrade to a Xenon bulbs?
Old Jul 26, 2010 | 10:27 AM
makav3li's Avatar
yes they are interchangable, and i did a xenon upgrade and it was just as easy as replacing the bulb, just had to add a ballast and mount it in the engine bay.
Old Jul 26, 2010 | 12:18 PM
eMacPaul's Avatar
However, the halogen housings aren't designed for the xenon light pattern, so it won't look good like using a xenon projector lamp.
Old Mar 7, 2011 | 07:59 PM
bleeg10's Avatar
Hey guys, the passenger bulb on my car went out, but I can't access the bulb without having to remove the filter. I've spent a good hour trying to figure out how to remove the filter to get the bulb, and i'm stuck. Does anyone have a diagram? Thanks!
A8Rob
Mar 15, 2015 10:28 AM
fullthrottle100
Jan 15, 2012 12:36 PM
ffdsmokeeater
Aug 29, 2008 10:22 AM
Greyster
Nov 26, 2007 12:51 AM
bwlawler
Nov 19, 2006 04:26 AM
