2012 A3: How do you adjust these f@cking head lights?!
Old Nov 12, 2012 | 01:10 PM
nmdenn2's Avatar
Default 2012 A3: How do you adjust these f@cking head lights?!
I would rate my automotive knowledge above average. I changed the timing belt and clutch on my 2006 VW BRM in my parents' driveway a few years ago. I swapped a couple Chevys and built one from scratch minus the machine work.... So I feel about damn stupid here but I cannot adjust the head lights on my A3.
I bought a Ross-Tech cable and found the adjust feature but in learn mode I am forced to manually adjust them. I have one too high or maybe the other too low but I do not know how to do it. I found some hex bolts (Allen) behind the head lights but they have no tensioning characteristics than I can see. What to do?
Old Nov 12, 2012 | 08:04 PM
Dasponto's Avatar
Which headlights do you have?
The hex bolts - if they are the manual adjustment screw's shouldn't feel much tension as they will spin freely (adjusted the headlights up or down) until you have reached the end of adjustment in that direction. Turn em on, pull up to a wall and turn the hex, see if the headlights adjust perhaps.
Old Nov 13, 2012 | 07:42 AM
nmdenn2's Avatar
I'm still learning Audi terms but I guess it's the Xenon range with LEDs. The bolts I speak of are directly behind the head lights close to the radiator. Seems like a couple turns and they're out. I wondered if I had the wrong ones.
Old Nov 13, 2012 | 08:18 AM
Dasponto's Avatar
Nope worries man! Always a learning curve going to new manufacturers. If you aren't 100% take a picture and post it up and I'll let you know. Should see a little plus minus sign possibly too.
But easiest way to know for sure is just light up a wall and give it a shot. I am 90% percent sure those should be your manual adjustment for the Hid's
Old Nov 18, 2012 | 12:55 PM
nmdenn2's Avatar
I could make it right no doubt if I could find the adjustment. Here's the pic. It seems to be just the mount for level sensors I guess. That's all I found.
https://www.dropbox.com/s/m7dcduu1gg...118_120938.jpg
konboy22
Jun 9, 2011 01:01 PM
Alicia
Jun 1, 2007 10:27 PM
mypreludeisred
Aug 9, 2006 11:08 PM
rickyzZ28
Feb 26, 2006 03:00 PM
BeefTaquito
Jan 25, 2005 01:41 AM
