98 gas tank
I had to replace the fuel pump and as I removed the pump from the tank the mounting bracket that is on the bottom of the tank came loose. [:@]
This is the one that the pump locks into so it stays in position. I think it has to be there or the pump will flop around.
Am I right in assuming that I will have to replace the tank, or is there a way to re-attach the bracket, or other fix??? [sm=sigh.gif]
