A3 3.2 changing cabin air filter
I want to replace the cabin air filter, but I can only find replacement instructions for old A3 models, mine is a '06 3.2 A3, can someone explain where/how to replace the cabin air filter in this model? Your help is appreciated.
I found it ! The cabin filter for an A3 2006-08, it's located underneath and behind the glove box, need to unscrew a couple of plastic screws, then there is cover you can slide to the left to uncover the filter. Just changing the filter and cleaning up the vents takes care of that bad smell typical from audi vehicles when you start the AC. Audi issued a technical bulletin 87-06-03 'Unpleasant Odor from Heating and Ventilation System (Aug. 28, 2006)' where they advise the dealers about this problem.
ORIGINAL: BAMF
So you access it from inside the cabin, right? Any idea on how often it should be changed?
