Which A3 to get??
ORIGINAL: Chef
In response to everything said...I would never suggest adding a boost controller without very good knowledge how the engine works and the ability to control the air and gas mixtures for the recommended boost.
Also, if you are chipped, then adding more boost is about as stupid as you can get.
Turbos are only able to run a certain level of boost...more boost = lower turbo life, overboost = turbo broken and possible complete engine failure.
Think...BOOM!
Cheers!
Think...BOOM!
Cheers!
umm a electronic boost controller is about 500 bucks.ok yes more boost means less life but its not like ur cuting 5 years off ur moter and second more u dont have to boost 16 and 17 psi all day long u can set it when needed.and it is more likey to blow if u put a manuel boost controller cause the ecu dose not want more boost.when u put a manual boost controller its like ur raping the ecu u will get what u want but it wont be as good.now with a electronic boost controller u go thru the ecu and it will do it willing u wont have to rape it.and as long as u keep it like 2 or 3 psi lower then ur fuel cut off u aint going to see no moter blowing up.i had a wrx and i had an apexi boost controller and i was boosting 17 psi and my fuel cut off was 18 and i drove that car for 2 years with that boost and there were no problems
This quote is from your Need Specs on A3 2.0T thread:
"hey im 16 geting a new a3 2.0t.and just wanted some specs on it like. power to weight ratio.and how much the turbo boost from stock.and any info will help thanks"
So you've been driving a WRX since you were 14?
The problem with a boost controller is, when boost is dialled up, does the car know to add more fuel to maintain the air/fuel ratio? On a "chipped" Audi, fuel level, timing, and many other maps are remapped to match the increased boost levels. A piggy back boost controller, e.g., the APEXi unit, will not control these factors with the level of precision that a reflash offers. I am not sure that the APEXi unit can even control the fuel delivery aspects of the A3. Keep in mind that the 2.0T is a FSI engine. So essentially you are relying to the stock ECU to compensate for the increased boost within its own maps.
THe A3 2.0T also responds very well to reflashes. A "reflash" is also $500 ~ $600, and is definitely the better option, both from a performance as well as a reliability viewpoint, although it does not offer a "the fast and the furious" cool factor.
Yuppie is correct. The fueling on the FSI engine is very precise and much different than any other car on the road.
Also, my point was that these little turbos have a breaking limit. What, how long, and how much hasn't been real world tested in our cars because they are very new. If your turbo fails, it may very likely take the rest of the engine with it. That was the additional caution I was throwing out there. It's one thing to boost enough pressure that the turbo itself goes, but quite another when it takes the rest of the engine with it.
Maybe someone will want to take a leap for the rest and do a long-term boost test? I'm just not willing to risk my nice ride for 5hp more.
Cheers!
Cheers!
ORIGINAL: gino123
ORIGINAL: Chef
Cheers!
Cheers!
ORIGINAL: a3_yuppie
Eh... the T in 2.0T stands for turbo. APR cites +49HP and +75ft-lbs, so even if you take those numbers with a grain of salt, those are still tremendous gains, considering that it's from a stock K03 turbo.
ORIGINAL: a3_yuppie
No problem... old guy with an Evo MR, I am digging it! When my eyes / contacts are dry after a long day, I read a lot worse, and I am not even that old, as most members who have attended the GTG's can attest to.
ORIGINAL: a3_yuppie
