A3 with lighting problems
Old Oct 26, 2015 | 10:23 PM
bobs11's Avatar
Default A3 with lighting problems
Hoping to get help from the forum experts:
I've got a lighting problem that just started on my 2011 A3 2.0T: all of the lights on the passenger side are out--headlight, front and rear turn signals, brake light, fog light, even the license plate light. And just to confuse me further--the LEFT rear turn signal. I used an OBDII reader to check for faults, but it came up with no errors.
Any suggestions about what might be going on?
Thanks,
Bob
Old Oct 27, 2015 | 12:40 AM
abjb's Avatar
Anything happen lately, work under the hood, in the trunk, close to the fuse panel.
Look for a wiring harness connector separated or partially apart probably close to the fuse box.
This many lights out same side is probably going to be a missing ground and not a fuse problem.
A Haynes service manual might help (wiring diagram), check at a local auto supply.
Old Oct 27, 2015 | 01:13 AM
bobs11's Avatar
Thanks for the suggestions.
Only thing that happened was that I had it valet parked while I went to a wedding reception. No problems when I dropped it off with them, but when they brought it back the warning light was on.
I'll look for a Haynes service manual to find out where the wire harness connectors are to try to track this down.
Old Oct 28, 2015 | 05:22 PM
sheldon's Avatar
You stated there was a warning light on - which one? You also said you checked for codes but nothing came up. Do you by any chance have access to a Vag-Com? Those generic OBD2 readers usually only check for engine codes and those internal light codes won't be throwing a CEL. The Vag-Com however would be able to get codes from the internal modules and usually help in pin pointing the issue.
Old Nov 7, 2015 | 12:25 AM
bobs11's Avatar
The "bulb out" warning light, showing every exterior light on the right side was out. I took it to the dealer and they found a blown fuse in the fuse block in the engine compartment. And a melted fuse panel around it. No idea where enough current to do that came from, but the dealer said they've seen it before.
Old Nov 8, 2015 | 12:16 AM
sheldon's Avatar
That sounds more like something warranty or a recall should cover. I melted fuse panel is not something I would simply pay for (hopefully they didn't charge you) as the Fuse should protect your internal components from exactly that kind of crap.
turbolove
Nov 28, 2009 05:12 PM
cristiancgarcia
Nov 29, 2008 06:36 PM
bradleykerr
Nov 4, 2007 11:29 AM
tinstt
Apr 19, 2007 01:57 AM
efloetry83
Feb 28, 2006 04:06 AM
