A3 standard sound system
Old Aug 27, 2007 | 04:54 PM
psun69's Avatar
Default A3 standard sound system
How can I remove the small base speaker from the luggage are of the car without loosing the sound from rear door speakers? If I disconnect the sub I loose the sound from the rear speakers in the car. Why does this happen? I have a standard (not Bose) system. The car is a 1997 Audi A3. any advice would be great!
Thanks
Old Aug 28, 2007 | 01:25 PM
converted's Avatar
Default RE: A3 standard sound system
I'm not familiar with the '97 model, but it sounds like the speakers must be run in series. So by disconnecting it you open the circuit cutting power to the door speakers. If you remove the sub speaker wires from the sub and connect the sub woofer speaker wires together the door speakers should work. In the '07 model which I have, the rear sub can only be disconnected at the speaker if want want to keep the back doors powered. There is a thread on here about how to accomplish this. I believe it's in the Newbie sticky at the top of the board. Relpy back if I've misunderstood anything.
jam1670
Jun 9, 2014 02:02 PM
Kratos907
Dec 25, 2013 11:29 PM
lilweezyana
B8 Models
May 30, 2009 12:47 AM
audi28XWJ
Aug 30, 2006 07:36 PM
