anyone changed their own transmission fluid on the DSG?
Old May 7, 2008 | 02:41 PM
converted's Avatar
Default anyone changed their own transmission fluid on the DSG?
My 35k mile mark is coming up soon and I was considering doing it myself. After looking at my Ebaun service manual it isn't as easy as I'm used to. Does anyone know how much the 35k service cost from Audi?
Old May 7, 2008 | 02:50 PM
cuski's Avatar
Default RE: anged their own transmission fluid on the DSG?
Here's an idea... have you tried calling a local dealership?
Old May 7, 2008 | 03:03 PM
converted's Avatar
As a matter of fact I was able to pick up the phone a few times before submitting my original post and have not heard back from my local Audi service department. Thank you for the insightful suggestion though.
Old May 8, 2008 | 10:49 AM
wtA3's Avatar
Member
Default RE: anyone changed their own transmission fluid on the DSG?
Automatic transmission fluid $ 60.00 Dust & pollen filter $ 17.35 Engine oil $ 24.00 Gearbox $ 37.25 Oil filter $ 13.00 Total Estimated Parts Cost $ 151.60
Labor Action Item Labor Cost Check for leaks Automatic transmission $ 3.30 Replace Automatic transmission fluid $ 33.00 Inspect boots & seals Ball joints $ 6.60 Check/service Battery $ 13.20 Inspect Brake system $ 19.80 Check level/refill as necessary Coolant $ 1.32 Inspect boots & seals Drive axles $ 6.60 Replace Dust & pollen filter $ 19.80 Check for leaks Engine $ 6.60 Change Engine oil $ 13.20 Inspect & check for leaks Exhaust system $ 3.30 Change fluid/filter Gearbox $ 46.20 Inspect & lubricate Hinges, locks & latches $ 3.30 Check/adjust Lighting $ 6.60 Replace Oil filter $ 6.60 Inspect On-board diagnosis system $ 6.60 Check level Power steering fluid $ 1.32 Perform Road test $ 13.20 Reset Service reminder light $ 1.32 Check condition Spare tire $ 3.30 Inspect & lubricate Sunroof $ 6.60 Inspect Tie rod ends $ 3.30 Check for damage and leaks Underbody $ 19.80 Rotate Wheels & tires $ 19.80 Check fluid level Windshield washer $ 1.32 Total Estimated Labor Cost $ 265.98
Total Estimated Costs Total Estimated Parts Cost For Your Area $ 151.60 Total Estimated Labor Cost For Your Area $ 265.98 Total Estimated Cost (excluding tax)* $ 417.58 *This Total Estimated Cost includes the preventive maintenance items recommended by Audi. The facility that services your vehicle may perform different, greater, or fewer procedures that can affect the cost you incur. For example, engine oil change and filter replacement are commonly performed by dealer and independent service facilities at special prices. These "special price" services do not typically include all of the additional procedures recommended by Audi at each service interval.
Old May 8, 2008 | 12:20 PM
converted's Avatar
Thanks for the info. The service manager called me this morning and quoted me at $550.
Old May 8, 2008 | 03:42 PM
BIGWAVEDAVE's Avatar
Hope its included in my extended sevice warrenty. I think it is.
Edit: Any one replaced the fluid with royal purple or Motul ect.?
Old May 8, 2008 | 03:44 PM
converted's Avatar
I'm not sure if it's the same service plan I was offered, but that one was only oil changes and it cost $600.
Old May 8, 2008 | 05:30 PM
4RINGSROD's Avatar
I so feal for all of you. It's nice having my '06 and no service cost for 5/50,000 I figure I'm going to save $1,500 - $3,000 in service cost expescialy since at 49,500 I'm going to have them do the realy expensive 50K check.
xqwizit
Dec 29, 2008 01:01 AM
brrman
Aug 20, 2007 07:48 AM
Dr Pooface
May 11, 2007 07:01 PM
