audi a3 1.8t smoking baaaaaaaaad
i hav a 1.8t on a 2000 plate that is smoking realy bad, its used a 1/2 ltr of oil in bout 15 mins i ha no visual leaks and a small bit of power loss? it smokes wen idleing but wen reved it is an emence amoount (filled my street in 30 secs and all was blind for 2 mins )how can i detect wats goin on b4 i go ahead and do head gasgit ?
It might be turbo or head gasket. If its the head gasket then you would see antifreeze on the dipstick or if you take the oil fill cover off. If its the turbo, then your car will run like crap and you wouldn't have any boost. If you have no oil in your antifreeze or antifreeze in you engine, then its the turbo. If otherwise then its the head gasket
Originally Posted by westhive4life
(Post 1384695)
What colour is the smoke?
Originally Posted by tufty118t
(Post 1384699)
but if it was the turbo if i had it running and puffin lots smoke and took of the front turbo to inlet pipe surley id see smoke in there but there is none obvoiusly the car cut out when removed ?
hih
Originally Posted by M.Tennant
(Post 1384789)
Be sure to post up the solution
