Audi A3 Quattro lower ball joint torque specifications
Can someone verify the lower ball joint torque specifications for a 2007 Audi A3 Quattro? The 3 bolts from the ball joint to the control arm.
The Audi A3 Quick Reference Specification Book (http://blogvager.files.wordpress.com...a3_qsb_web.pdf) states it is 60Nm, but if I try to torque to that spec, it strips the bolt and nut.
I have seen other forum posts that say 20Nm +90 degrees?
Does the suspension need to be under load?
Is the spec book incorrect?
Thanks in advance.
Thanks in advance.
rupenzelleo
Jan 21, 2015 07:29 AM
