Audi A3 Tail Light...One Bulb Won't Work!
Old Aug 29, 2012 | 02:27 PM
trademe23's Avatar
Default Audi A3 Tail Light...One Bulb Won't Work!
Annoying problem...one bulb on my drivers side tail light won't work.
This is what I've tried so far:
Changed the bulb (tried numerous bulbs)
Checked all the fuses
Replaced the holder
Anyone have ideas as to what I should look at next?
Old Sep 18, 2012 | 10:35 AM
tclatin5's Avatar
Did you ever get an answer on this??? I'm having the same problem...
Old Sep 18, 2012 | 10:54 AM
z28pete's Avatar
Trace the wire from bulb to fuse & look for damage.
Old Sep 18, 2012 | 02:34 PM
trademe23's Avatar
No, I'm still trying to track down the issue. Though, the other day I noticed that when I lock the car the non-working bulb blinks as normal. Does yours work like that as well?
Old Nov 3, 2014 | 01:20 PM
bigpuddy's Avatar
Default Rear brake light
Any solution to your rear brake light? Im having the same issue. have replaced the bulb- didn’t work. going to clean out entire assembly and connection and see if that helps.
Ill post any progress I make.
Old Apr 13, 2015 | 02:39 PM
velasdad's Avatar
Default anyone?
Anyone resolve this? Same issue, driver side lights in the hatch won't light. Also one light in the main body housing (think its led cause its built in) doesn't light either. Changed all bulbs. Nada. Anyone have a solution?
colitm8
Mar 15, 2010 10:20 AM
MagicHobo
Nov 14, 2008 01:37 AM
tsk
Apr 27, 2008 04:56 PM
pheonix_625
Oct 10, 2006 12:57 PM
Jestnomen
Oct 12, 2005 11:27 PM
