i already got somechipped paint at the front of my car... doesthe clearcoatreally help??
RE: Clearcoat?
I agree with Blue Jays, the factory paint job from Audi is superb. Though, like Steven, my car has a couple of nicks on the hood from stones on the highway. Basically, nothing you can do about it, and an extra clear coat is unlikely to do much to help. My advice is to save the money and down the road get it repainted when you can't stand the scratches anymore. Unfortunately, black cars, as much as I love them, really show the scratches.
What about paint protection films? A local tint centre has this on their website.
Paint Protection Film FAQ's
What is it?
Paint Protection Film is a clear 8-9-mil polyurethane material that is applied to painted surfaces and protects against damage to paint caused by bugs, rocks and other debris.
Who makes it?
Paint Protection Film is made by a number of manufacturers including 3M, Avery Dennison and Venture Tape.
What parts of my vehicle can be covered?
Any painted area requiring protection from abrasions, rock chips etc. can be protected. Pre-Cut kits are most commonly available for areas that may receive damage such as the hood, fenders, frontal bumper areas, and mirrors.
Will it turn yellow? What is the warranty?
3M warrants their film for a period of 2 years. Venture Tape has a lifetime warranty against turning yellow.
Will the paint under the film fade differently from the rest of the vehicle?
The Paint Protection Film contains only enough UV inhibitors that keep the film from turning yellow; this allows the paint under the film to fade evenly with the rest of your vehicle.
How easily will it peel off?
The material has a strong adhesive to help keep it firmly attached to your vehicle. In the event you decide to remove the film, an easy release system is activated by stretching the film until the adhesive begins to release. Once the film is removed, the same material cannot be reused.
Is any special care required for my Paint Protection Kit?
Paint Protection Film should be cared for in the same way you would care for the paint on your vehicle. The product can be washed and waxed along with the rest of the vehicle. If any wax residue remains at the edge of the film it can be removed with a soft bristled toothbrush. If you use a high pressure wash to clean your vehicle, you should keep the high pressure nozzle at least 5 inches from the edge of the film to prevent lifting of the edge.
How is it installed?
Paint Protection Film should be installed by a professional installation center. A professional installer will apply the sheets of Paint Protection Film using a special application solution and special application tools to ensure a clean, clear, bubble-free installation that will last for many years.
How much is it?
Paint Protection Film kits vary based on how much coverage is required for your specific vehicle. Generally speaking, the cost to protect the hood and fenders is between $250 and $300. The cost to protect the entire front end of a vehicle with a full painted front bumper can be as much as $700 depending on the amount of coverage required. Pre-Cut kits are also available for some vehicles to protect the rocker panels down the side of the entire vehicle.
RE: Clearcoat?
IMHO these 'solutions' look worse than the scratches etc they are meant to avoid. Despite what they say, you can always see the lines, and the light does not reflect of the covered sections in the same way as the uncovered sections. So, you might avoid scratches on these sections, but from day one, your car will have a bit of a two-tone look.
Some people really love this solution. To me, it's aesthetically worse than the problem. Basically, if you drive your car, it's going to get scratched. Not much you can do about it other than wax it and take care of the bad scratches/dings right away. When my A3 got her first scratch I was very upset. She's had a couple more very minor ones, but I look at is we are growing old together.
RE: Clearcoat?
Quote:
ORIGINAL: TPE_A3
Very, very wrong. It's a great product and on my color can barely be seen if applied properly. Research the product before making those comments.ORIGINAL: TPE_A3
RE: Clearcoat?
"Very, very wrong. It's a great product and on my color can barely be seen if applied properly. Research the product before making those comments."
Hmmm. First, that is a bit subjective. To me, if I can see it, I don't like it. Plus, I couched my response is so many conditionals so as avoid any flame bait! Please check my post, I said...IMHO...For ME..... etc.
As for why I may be so picky...I am in the architecture and design field. I make my living in part because of design aesthetics, which very much include colour and texture. Thus, I stand by what I said...these solutions look worse than the problem they are meant to avoid. And as I noted, not everyone agrees! That does not make one right and the other very very wrong! And nothing else that I said goes against conventional logic, I'm sure everyone's car has a scratch, chip or dent somewhere if they have had it for a few months and drive it!
Usually the tone in these forums is super-relaxed. Hope that you realize I was simply expressing my opinion, which is, after all, the point of a forum!
