:: ECS Tuning :: NEW!! 8V A3 1.8T/2.0T ECS Performance Baffled Oil Catch Can
An unfortunate consequence of the modern closed PCV/Breather system is the unintended ingestion of oil vapor and carbon into the intake tract, lowering the octane rating and leaving harmful deposits on a vehicle's intake valves and ports that result in decreased power.
Engineered in-house and manufactured here in the USA, the ECS Baffled Oil Catch Can utilizes a highly efficient 4-chamber oil separator, decreasing oil ingestion and maintaining engine power output.
The innovative design also catches as much blow-by gas as possible, bringing carbon buildup to an absolute minimum.
Key benefits of the ECS Tuning Performance Baffled Oil Catch Can System:
Highly Efficient Oil Separator (Catch Can):
Strategically positioned 4 chamber baffle system maximizes oil / air separation
Engineered to create multiple changes in the direction of airflow within the separator to cause oil droplets to fall out of suspension before exiting the catch can
Knurled and black anodized integrated oil dipstick makes inspecting oil volume of the reservoir clean and simple
Fully serviceable for routine cleaning and maintenance; Includes 2.5mm allen key to remove baffle plates for cleaning
-10AN ORB (O-Ring Boss) fittings for leak-free fitting connections
6061-T6 billet machined body, anodized black for lasting protection and appearance
Easy to drain reservoir, simply un-threads from the oil separator for quick draining or cleaning
The OEM Audi fine oil (cyclonic) separator is retained. Due to the retention of this component, the catch can will not have to be emptied as often, as its focus will be on capturing the ultra-fine oil vapor
**Engine cover fitment is maintained with no modifications needed**
Completely reversible installation, as no OEM components are permanently modified
OE style appearance once installed
Each system includes the following:
- 4 Chamber Baffled Oil Catch Can with integrated dipstick and service tool
- CNC bent, black anodized, aluminum catch can bracket
- -10AN black nylon braided hose
Cut to the perfect length -- This alone make's installation as easy as changing your own oil!
-10AN black anodized swivel fittings are pre-installed on each hose for a direct fit install
DEI Heath Sheath pre-installed on catch can hoses for clean and protected hose routing
Oil and fuel resistant to chemical degradation
- OE Style hose stand-offs for proper hose support against A/C lines
- PCV Adapter Fitting and Locking Plate
- Turbo Inlet PCV Fitting
What are YOU Ingesting?
Click HERE to order or for more information
Be sure to check out our -----> Installation PDF
Let me know if you have any questions.
Jason
ECS Tuning
B7 Models
Sep 1, 2015 01:16 PM
ECS Tuning
Sep 1, 2015 12:27 PM
ECS Tuning
B8 Models
Sep 1, 2015 12:11 PM
ECS Tuning
Aug 12, 2015 04:11 PM
