Engine Management Light, Air Mass Flow Meter, Door Open Warning, ESP
Old Oct 5, 2006 | 12:46 PM
jaimewood's Avatar
Default Engine Management Light, Air Mass Flow Meter, Door Open Warning, ESP
Just had a number of issues corrected on my ’02 S3 with 44k on it and thought the info could be useful to others….
Engine Management warning lamp indicator on the dashboard. This is the yellow symbol which looks like an engine, in the Speedo dial area. The light came on for four days, and then went off the day I took it to Audi! However the problem had been recorded into memory. It was related to the Engine Coolant Temperature sender. Replacement cost inc VAT: £150.
Also, they said the Air Mass Flow Meter needed replacing. This regulates the turbo airflow I believe, and it is a regular fault with many Turbocharged VW/Audi’s inc TDI’s. However I already knew this was a problem as they reported it in the last service even though everything was running fine, although the Eng Mgt light had not been on for that one. Cost: £197.
Finally, on closing the drivers door, the dash still registered that the door was open. This was a pain because the interior lights stayed on whilst driving, and the alarm would not arm on locking the car. New Lock required: Cost: £215
The other intermittent issue is the fact that the ESP Off Warning light comes on and stays on and then goes off at its own free will very occasionally. This is getting fixed next week.
Old Oct 9, 2006 | 01:25 PM
adamnb's Avatar
Default RE: Engine Management Light, Air Mass Flow Meter, Door Open Warning, ESP
The door switch is a common fault as this happened on my 2001 s3,
the actual part though was around £40 and not a massive job to fix, £215 pound sounds a little steep to me
Old Oct 17, 2006 | 07:44 PM
owen's Avatar
what about the Air Mass Flow Meter any ideas how much this costs and what sort of a job it is
Old Oct 17, 2006 | 07:51 PM
techbod's Avatar
ORIGINAL: jaimewood
I think you seriously got screwed by the dealers get one of these and save many ££££$$$$$
https://www.audiforums.com/m_370295/tm.htm
hitman1978
Jan 11, 2010 03:04 PM
decbohan22
May 25, 2008 07:08 AM
steve the red
Jul 15, 2007 05:06 AM
Weeble
May 30, 2006 02:46 PM
VAa8L01
Dec 27, 2005 08:14 PM
