Is the Forge adjustable BOV spacer a real BOV?
Old Jan 23, 2008 | 07:30 PM
Ipsodox's Avatar
Default Is the Forge adjustable BOV spacer a real BOV?
So I can't seem to find a solid answer for this...
Does the Forge adjustable BOV spacer actually vent everything to atmosphere, or does it just make the BOV sound (by venting a small amount)? I'll eventually be getting the Forge DV before chipping my car, but I'm interested in the BOV spacer. The fact that it's a 'spacer' makes it sound like it just imitates the sound of a real BOV, while still maintaining a DV's recirculation function.
Can anyone shed some light on this?
Old Jan 23, 2008 | 10:45 PM
Chef's Avatar
Default RE: Is the Forge adjustable BOV spacer a real BOV?
ORIGINAL: Ipsodox
It vents a small amount of air and the rest is recirculated. Personally, I would just get a CAI and bypass the BOV. You will still get most of the sound. Spend your money on something more worthwhile.
Cheers!
Old Jan 24, 2008 | 08:11 AM
dqx2001's Avatar
NOOB HERE!
Excuse my ignorance but whats aCAI and whats it stand for?
Old Jan 24, 2008 | 08:25 AM
lavadrifter's Avatar
CAI = Cold air intake. Search Neuspeed P-flow for an example. You'll hear the blow off through the air intake filter. Can't miss it!
Old Jan 24, 2008 | 02:04 PM
patty AT forge's Avatar
The adjustable can be set to release all of the air to atmosphere, a 50/50 split, or recirc everything... the non-adjustable is 100% atmo.
Old Jan 24, 2008 | 03:43 PM
Chef's Avatar
Good to know Patty. How does the car compensate for releasing the measured air to the atmosphere? Shouldn't that make the car run much richer?
Cheers!
Old Jan 25, 2008 | 09:28 AM
The spacers were both developed before I started with the company but from what I've observed during the prototyping of the DV replacement the car just doesn't care about the vented air, the logs with the spacer deviate no more than they would run to run without the spacer. I don't know specifically what is happening but I have three theories:
1. The amount of air vented is below the resolution of the MAF to detect
2. The amount of air vented is within the normal accpeted parameters of the ECU
3. The ECU ignores the MAF while it is actuating the DV and relies on the MAP
Old Jan 25, 2008 | 10:00 AM
Chef's Avatar
Yeah, I've noticed that my car didn't throw any codes or have a problem when I had what I consider to be a huge boost leak, losing 5-7psi. There must be a large tolerancethat the ECU allows?
Cheers!
jhlax57
B7 Models
Jan 21, 2010 10:05 AM
slick2xr
Dec 18, 2008 02:07 AM
slick2xr
B7 Models
Dec 17, 2008 07:19 PM
a4forever
Aug 19, 2007 02:36 PM
HID
Aug 14, 2006 05:46 PM
