Here are the ultimate pedals !!!
Hope you guys enjoy the pics of my recent mod.
This actually took me less then 1 hour. The instructions these bad boys come with are actually very easy and dummie proof.
All these instructions are on the ultimate website.
1. Our driver foot rest is anchored by one screw, and metal clip upper right hand corner.
There is also a big plastic clip on the driver door side anchoring to the plastic wall, once the screw and metal clip are removed the
whole unit comes out very easy. Place new foot rest flush with floor board and flush with the plastic wall . Under the area where
the old foot rest was, is a thin metal plate drill right thru but not deep there might be wires back there two srews and its solid.
2. Brake pedal, just pull the top of the rubber cover towards the rear of the vehicle and of it comes. There will be two holes on the
existing brake pedal the hole to the right you can use as an pilot hole, the srew and nylon lined nut fit perfectly.
The next hole to the left has to be drilled, use a small drill bit before you use the correct size bit to make life and drilling easier.
apply second nut and srew. FYI if you have big feet like mine size 11 you can slide the new brake pedal to your left a little
to create space for gas pedal to brake pedal transition while driving, i always thought those two pedals were too close to one
another. Two srew and nuts required for this pedal and it to is solid.
3. Gas pedal is alll plastic nothing to remove and again the ultimate pedal is perfectly cut to perfection, I lined it up with the top of
the pedal, which left it perfect at the bottom crease of the pedal
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG]
Sorry guys I hit return by accident anyway lined up the top of the gas pedal and it lined perfect with the bottom fold of the gas pedal.
Two srews and your done.l here are the pics.
I'm diggin' it.
I would have chose to put "A3" on all 3 of the pedals, but at least your chose to put the rings instead of something goofy like "SS" or "Type R"
How much did it set you back and now that you've driven with them a little more, what are your impressions?
The pedals cost a total of $238.00
1. 10.00 shipping
2. 10.00 engraving each pedal.
This is their end of summer sale so act now, it comes to about a 25% discount.
Evoic they feel and look great, the biggest improvement for me was that i was able to slightly move the brake pedal over a little to the left so my foot wouldn't get stuck when i went from the gas pedal to the brake pedal.
The frosted finish is the way to go if anyone is thinking about this upgrade, the color matches the brushed metal on the doors.
And get the anti slip so you wont need the rubber inserts wich cost more .
1. 10.00 shipping
