IDLE GOES HIGH AND THEN DROP! PLEASE HELP!
Old Dec 19, 2006 | 03:38 AM
adexplosion's Avatar
Default IDLE GOES HIGH AND THEN DROP! PLEASE HELP!
It's about Audi A3 from '99. The idle goes up around 3000rpm and then drop to 0 usualy when it's a little cold, but sometimes doesn't matter even when it's warm outside or the engine is warm or hot or cold doesn't matter. can anyone help me please with some ideas ??? thank you.
Old Dec 19, 2006 | 04:50 AM
Flip's Avatar
Default RE: IDLE GOES HIGH AND THEN DROP! PLEASE HELP!
It sounds like a gasket leak somewhere, perhaps your intake manifold gasket.
Old Dec 19, 2006 | 02:21 PM
barks's Avatar
SOunds v similar to mine - also 99 A3. Had trouble starting when warm.
Turned out to be a faulty coolant sensor, causing too much petrol to go into the mix. Replaced sensor and all fine.
Old Dec 19, 2006 | 05:19 PM
Jex's Avatar
Jex
Or another sensor - random stalls in mine were caused by a faulty engine speed (rpm) sensor.
muckdawg24
Aug 23, 2008 06:01 PM
freestyleski
Oct 8, 2007 11:09 PM
kingtut
Sep 19, 2007 10:36 PM
moeron7
Mar 23, 2007 03:47 PM
