Intermittent Power Windows
Old 04-15-2008, 11:41 AM
TPE_A3's Avatar
Default Intermittent Power Windows
Hey all,
Has this happened to any of you?
My front passenger side window will roll down when using the driver's side button, but about 50% of the time, it will not roll up from the driver's side. Reach over and roll it up just fine with the passenger's side control. Other times, the driver's side works. Seems totally random.
Any suggestions?
Old 04-15-2008, 11:54 AM
Swaynest's Avatar
Default RE: Intermittent Power Windows
Never had that problem
Old 04-15-2008, 05:26 PM
BIGWAVEDAVE's Avatar
Having that problem now, it just started.
and I just had my rear motor replaced... everytime I would roll the window up it would go down.
weird
Old 04-16-2008, 10:20 AM
Audiaddict's Avatar
Mine started doing that after my ECU was reprogrammed. My clock is also a diff. time every time I start the car. kinda annoying!
Old 04-16-2008, 02:17 PM
robertmrome's Avatar
Very similar issue here but with the rear passenger window... It just kinda fixed itself after a few days but who knows for how long it will stay fixed.
Sorry no suggestions...
RR
Old 04-16-2008, 04:52 PM
dcny7777's Avatar
Mine started doing the same about 1 week ago.
And its the left rear window.
It doesnt go all the way down when you "one click" with the drivers side window button.
Old 04-16-2008, 08:02 PM
TPE_A3's Avatar
Seems like I'm not the only one with gremlins in the windows!
Next week my car is going in for service, and Audi Taiwan is having the tech from Germany who trains the Taiwan techs to look at my car for another problem, and this one too. I'll let you know if I find a resolution to the problem.
Old 04-16-2008, 11:47 PM
tm2131's Avatar
Hey guys i had a similar problem with my 07 2.0t drivers side rear. for a few weeks when i would either put the window up or down it would get half way then it would jerk up and down for a but before deciding weather or not it was going to be up or down. Then one day it just seemed to start working. Pretty weird but it hasn't happened since.
Old 06-08-2010, 11:41 PM
joelsindc's Avatar
anyone get this fixed? Mine started doing this recently, of course I have 48k, just within warranty. haven't noticed it on the rear windows, though I don't use them often. Definitely on the front two, and happens often, almost as if the button doesn't work, or when it does work, just opens a cm, and then stops...did not realize Gremlins came for free.
Old 07-06-2010, 12:35 AM
masterducky's Avatar
I know what the problem is.
Its the plastic clips that raise the window that are broken.
HTML Code:
http://www.audi-sport.net/vb/showthread.php?22915-Faulty-S3-Electric-Window-Fix&p=597347
Quick Reply: Intermittent Power Windows
