Let's get the 8V / MK7 peeling roof recalled already!
Old Jul 31, 2025 | 12:05 AM
lespaul2510's Avatar
Default Let's get the 8V / MK7 peeling roof recalled already!
Like many of us, my 2015 8V A3 has had peeling clear on the roof for quite some time and I'm determined to do something about it because Audi won't. I'm submitting a recall complaint to the NHTSA (click here) in hopes to have the issue escalated and I encourage y'all to do the same. Super easy, shouldn't take more than 5 minutes.
To save everyone some time, I made an AI prompt to do most of the work for you. I'm assuming ChatGPT for ease of conversation, but use whatever you like (Gemini, Grok, whatever... though I find the best results with ChatGPT). Just copy/paste the first two boxes below verbatim.
Initial ChatGPT Prompt
You are an NHTSA recall complaint randomizer.
I will provide you with a **template complaint** about a vehicle safety or defect issue. Your job is to:
2. Rewrite the complaint to make it **unique but truthful**, staying under the 2,000-character NHTSA limit.
3. Vary phrasing, order of details, and point of view—while keeping the core facts intact.
4. Do not reuse links or mention character count or image upload issues. At best, expand the shortened URL's and provide only one or two examples, but not all of the examples provided in the sample.
You should aim to make each version **look and sound like a real, individual submission**, not a copy-paste. Do not ask for a hashtag at the end of the complaint.
When ready, begin by asking:
“Please paste your template complaint. Then I’ll ask you for some quick personalization details.”
Template Complaint
The plastic roof trim panel on my 2015 Audi A3 is peeling and deteriorating significantly. This is not painted metal—it’s a separate, non-paintable plastic component that runs along the sunroof and roofline. The surface began flaking and lifting over time, and multiple independent body shops confirmed the panel is failing structurally and cannot be refinished—it must be replaced.
While this may appear cosmetic, it’s not. The panel protects the roof seam and substructure, and its failure creates risk for water intrusion, corrosion, and compromised roof integrity—a serious safety concern, particularly in a rollover or high-impact crash.
Owners of vehicles on the same MQB/8V platform—including the VW Golf and SEAT Leon (not sold in the U.S., but structurally similar)—have reported identical issues, often followed by cracking or full detachment of the panel.
Despite multiple attempts to resolve this, Audi of America has been largely uncooperative. Their warranty process requires a diagnosis from an Audi dealer, but most dealers don’t perform bodywork and refer customers to third-party shops—whose assessments Audi then refuses to accept. I’ve been stuck in a loop with no viable path forward, despite this being a documented, recurring issue.
This appears to be a design or material defect that deserves investigation before it results in more severe safety or structural failures.
See the URLs below for public documentation of similar cases:
https://tinyurl.com/55kuxryc
https://tinyurl.com/4djmuxau
https://tinyurl.com/55nbvve7
https://tinyurl.com/42ny8fjv
https://tinyurl.com/33e62c8r
https://tinyurl.com/3rdrzc9b
https://tinyurl.com/4te4dhwp
Excuse the shortened URLs—this was necessary to meet the form’s character limit. I was also unable to upload images due to file size issues, but I’m happy to submit them by email upon request.
One more note: I’ve noticed most of the affected vehicles appear to be blue or darker in color. Possibly a heat-related materials failure?
Respond to everything below as you would normally. Everything else is for example purposes only. Your AI may respond slightly differently.
Typical ChatGPT Response
Thanks for sharing your detailed template! To create a unique, truthful, and personalized NHTSA recall complaint rewrite, could you please provide me with a few quick details about your specific experience? For example:
  • Exact vehicle year, make, and model (if different or more precise than 2015 Audi A3 8V)
  • Approximate mileage when you noticed the issue
  • When and where you first observed the peeling/deterioration (season, location)
  • Any contact with dealerships or repair shops and their response
  • Whether you’ve noticed any related problems (like leaks, corrosion, or structural concerns)
  • Any other specifics you feel are important
Once I have those, I’ll create a unique version of your complaint that fits your situation while staying within NHTSA guidelines.
Fictitious Example (you want to provide as much detail as possible here, even if it doesn't ask for it. The more detail, the better the result... I just did something quick and dirty with intentionally poor grammar)
2018 Audi RS3, 40000 miles, noticed in 2020, I live in Arizona. I have contacted one dealership, they asked me to pay money to have the car evaluated. The roof has cracked. Fortunately it don't rain much here. but a crack is a crack.
Fictitious Result (obviously you're going to want to submit documents/photos if they fixed the form)
I own a 2018 Audi RS3 with about 40,000 miles. Back in 2020, I first noticed significant deterioration of the plastic roof trim panel running along the sunroof and roofline. This is not a painted metal part, but a separate plastic piece that’s supposed to protect the roof seam. Over time, the panel began cracking noticeably.
Living in Arizona, where rain is rare, I haven’t yet experienced water intrusion, but a cracked panel like this still raises serious concerns about potential corrosion or damage to the roof structure, especially in the event of an accident or rollover.
I reached out to an Audi dealership for help, but they required me to pay for a diagnostic inspection before even considering any warranty coverage or repair. Given the widespread nature of this issue on vehicles built on the same platform, this response is disappointing.
I believe this defect stems from a design or material flaw that Audi should address proactively before it leads to more serious safety risks. This problem isn’t isolated to my vehicle alone; other owners of Audi models on the MQB/8V platform have reported similar peeling, cracking, and detachment issues with this roof trim.
Audi’s unwillingness to cover the repair under warranty or acknowledge the problem leaves owners stuck with costly fixes for what should be a manufacturer responsibility. I urge NHTSA to investigate this issue to protect consumers and ensure vehicle safety.
ECS Tuning
Aug 6, 2015 03:22 PM
Audi Forums Editor
Jun 2, 2015 11:38 AM
toro745
Aug 11, 2010 12:51 PM
sttjackett
Mar 31, 2008 07:01 PM
leejj
Dec 6, 2007 04:06 PM
