Malfunction Indicator Lamp
Hi,
I have an A3/2006/48,000 and my malfunction indicator lamp just came on, regular service/new battery any idea's? |
Which symbol?
Originally Posted by azoceanblue
(Post 977639)
Which symbol?
That can be a wide range of problems - from your gas cap not being tightened, to a worn cam lobe/ fuel pump drive, to your car needing software updates. Most common is the intake manifold flap malfunction.
At any rate, you need to get it to a dealer (or a shop that has a Vag Com), get the codes read and reset, see what's up. No urgency if the car has oil, water, and runs fine, but best get it done (mines been lit up for a month - 3rd time). |
Originally Posted by hesaputz
(Post 978089)
your still under the 50K go to your dealer and get it looked at ASAP so they cant charge you.
Thanks
Thanks Everyone,
Took it in today and yes I was still under warranty, I had an over-run cut off valve that was faulty and they also had 2 recall items that they performed on my car. Car is running great. Thanks again, Mary |
Gotta Love Warranties :)
| All times are GMT -4. The time now is 02:01 AM. |
