Malfunction Indicator Lamp
Old Oct 26, 2008 | 03:18 PM
Mary's Avatar
Default Malfunction Indicator Lamp
Hi,
I have an A3/2006/48,000 and my malfunction indicator lamp just came on, regular service/new battery any idea's?
Old Oct 26, 2008 | 04:53 PM
azoceanblue's Avatar
Which symbol?
Old Oct 27, 2008 | 08:40 AM
Mary's Avatar
Originally Posted by azoceanblue
Which symbol?
The yellow light that looks like an engine.
Old Oct 27, 2008 | 10:04 AM
hesaputz's Avatar
That can be a wide range of problems - from your gas cap not being tightened, to a worn cam lobe/ fuel pump drive, to your car needing software updates. Most common is the intake manifold flap malfunction.
At any rate, you need to get it to a dealer (or a shop that has a Vag Com), get the codes read and reset, see what's up. No urgency if the car has oil, water, and runs fine, but best get it done (mines been lit up for a month - 3rd time).
Old Oct 28, 2008 | 03:29 PM
tdotA3mike's Avatar
I had both those problems the lobe and flap motor they had to replace the whole cam shaft as well.. but yes it can be for many different reasons if you don't want to go back to the dealer try and find a place or mechanic that has the ability to read the code and see what it is.
Old Oct 28, 2008 | 05:40 PM
4RINGSROD's Avatar
your still under the 50K go to your dealer and get it looked at ASAP so they cant charge you.
Old Oct 28, 2008 | 08:26 PM
Mary's Avatar
Default Thanks
Thanks Everyone,
Took it in today and yes I was still under warranty, I had an over-run cut off valve that was faulty and they also had 2 recall items that they performed on my car.
Car is running great.
Thanks again,
Mary
Old Oct 28, 2008 | 09:56 PM
Smile
Gotta Love Warranties
StaticA4
B8 Models
Oct 1, 2010 05:00 PM
yankegg
May 6, 2010 04:44 PM
JBA3
Oct 15, 2009 01:28 PM
dha514
Apr 8, 2008 09:10 AM
dpaki
Jun 6, 2004 11:24 PM
