noise from gearbox in neutral
Old Sep 15, 2007 | 02:29 AM
yarkony's Avatar
Default noise from gearbox in neutral
I have A3 2.0T quatro 6 gears manual tranny 2007 10K kilometers. There is a "grrr..." noise from the gear when in neutral which disapears when pushing the clutch. Is it normal? What should be done?
Old Sep 15, 2007 | 02:48 AM
yarkony's Avatar
Default RE: noise from gearbox in neutral
ok
Old Sep 15, 2007 | 02:50 AM
techbod's Avatar
sounds like the thrust bearing is bad so if you have a warranty get the clutch and all its parts changed, clutch plate/pressure plate and thrust bearing which should be done and not just the bearing that's bad practice because you get problems later doing it that way
Old Sep 15, 2007 | 02:54 AM
yarkony's Avatar
It is gone once pressingthe clutch, so it is not the clutch...
Old Sep 15, 2007 | 09:48 AM
techbod's Avatar
the noise is a vibration from the thrust bearing which pushes the pressure plate in and that's why the noise stops when its pressed in
edit: im not saying the clutch has a problem but for the thrust bearing to go within 10k would suggest there is a problem waiting to happen and personally if it were me I would expect the lot to be changed under the warranty
Old Sep 15, 2007 | 08:47 PM
Chef's Avatar
Listen to him, he's correct.
Old Sep 26, 2007 | 12:37 PM
yarkony's Avatar
They want to change firstly the Flywheel...and then if does not stop - the whole tranny. what so you think?
It is a 10K car..
Bluud
Jan 27, 2014 04:30 AM
tudii
Dec 11, 2012 03:29 PM
APR_TT
Jun 19, 2008 07:53 PM
yarkony
Sep 18, 2007 11:03 AM
