P0171 and Oil Leak
Old Apr 29, 2014 | 12:53 PM
jamiesue972's Avatar
Default P0171 and Oil Leak
Having problem with my 2009 A3, base model. My engine light came on (which it does periodically, but goes off after a day, always has), this time it stayed on. I ran it in to Auto Zone to run code, got P0171. Went ahead and made apt with Audi, thinking issue maybe still under warranty. (car had 118k miles at the time, yes I drive a lot, about 25k a year). First, I don't like my Audi dealer in my area. Second, they told me code wasn't a big deal, some type of pressure issue, not under warranty, fix when can (at $600 price tag). But they said in their review they found a small oil leak. I had noticed same, but seems I have always had to add oil every now and then anyway, these forums say yeah, Audi. I started paying more attention and sure enough, seeing oil on garage floor, adding a quart about every 2 weeks. My question is, any merit to these additives that you can use that help seal up leaks? Or do I need to skip those and go with the fairly hefty price tag Audi gave me for repairs? I absolutely love this car, but like I said, I do drive a lot, about to start driving more with a kid playing college ball 7 hours away this fall. I can't decide if I keep putting money into it or time to trade.
Old Apr 30, 2014 | 09:52 PM
milo65's Avatar
Find out where the oil leak is coming from. I have a '06 A4 with 117K on it, had an oil leak and was worried about what it would cost. I went to my local mechanic (not a dealership) and found out I had two leaks. Valve cover gaskets ($200 installed) and oil cooler gasket ($300). I had him do both, but really could have just got away with just the oil cooler gasket, since the valve cover was not bad. As far as your code. I did throw have it once. It ended up being the PCV valve, it was a very quick and cheap repair (less than $300). The valve is plastic and over time it expands and contracts and starts to lose it's seal.
Old May 1, 2014 | 08:50 AM
CRAZYHAWK's Avatar
P0171; check for vacuum leaks.
Find an independent mechanic.
Old May 1, 2014 | 04:11 PM
Any suggestions of a good independent in Oklahoma City area? I guess I'm leary of just anyone since it's a fickle car as it is.
Old May 5, 2014 | 01:34 PM
CRAZYHAWK's Avatar
chriscurra
Jun 13, 2015 02:44 PM
The Bebop
Apr 15, 2011 01:28 AM
brob
Oct 6, 2010 10:04 AM
bluetee01
Apr 27, 2009 12:45 PM
MatDHan
Apr 26, 2009 01:36 PM
