replacing instrument cluster without computer
Old Nov 22, 2006 | 05:39 PM
ruidr's Avatar
Default replacing instrument cluster without computer
hello,
i need to replace my instrument cluster without computer, for new one with computer anda i dont have the cable to atach them in the instrument...
where i buy the cables?give a intructions to replace them please....
thanks
Rui
[IMG]local://upfiles/19678/CD5BC1239F0540EFB425E5EDC06C3DA9.jpg[/IMG]
Old Nov 22, 2006 | 05:46 PM
techbod's Avatar
Default RE: replacing instrument cluster without computer
chances are it wont work because the ECU isn't up to it and no data could be sent through wires/ sensors you don't have
Old Nov 22, 2006 | 06:00 PM
ruidr's Avatar
they're possiblities for install ,to keep only instrument cluster but de information center disable?
i spend 150€ to this, if its possible tell me how do that...please
Old Nov 22, 2006 | 06:03 PM
techbod's Avatar
quite simply you cant due to the wiring and connectors
Old Nov 22, 2006 | 06:26 PM
a3_yuppie's Avatar
SoCal Crew Member
Read this thread in its ENTIRETY.
http://forums.vwvortex.com/zerothread?id=2225482&page=1
I am assuming that you have a 2006 or 2007 A3. You do NOT need to replace the cluster. You need to ENABLE the trip computer, and INSTALL a more "advanced" wiper stalk if you want to access the functions of the trip computer.
As for sensors, or the lack thereof, the only one at issue is the low wiper fluid warning. Probably not worth it to get sensor and install it.
Old Nov 22, 2006 | 06:31 PM
techbod's Avatar
its the connector I was concerned with ( how many pins ) for the old verses the upgrade, sensors are not a problem they are there or not if the system cant see them then they don't exist
Sean_Burgess
Nov 6, 2014 02:41 PM
staticdrop lee
Feb 21, 2013 11:16 AM
asutherland
Jan 22, 2010 09:58 AM
theemaster
Oct 28, 2007 12:24 PM
MJSCC
Sep 5, 2007 03:24 AM
