service interval reset
Old Apr 18, 2006 | 09:22 PM
maciej's Avatar
Default service interval reset
Could any tell me how to reset my service interval display? I passed the 10,000 mile mark and the light came and service isn't due until the 15,000 mark. I looked at owners manual and tried to follow the directions and it isn't working. Is there a trick that I am missing? Thanks
Old Apr 19, 2006 | 11:42 AM
crusader's Avatar
Default RE: service interval reset
As far as I know it can only be re-set by the dealer with the appropriate equipment
Old Apr 20, 2006 | 02:27 AM
freeflow's Avatar
Member
it says how in the manual somewhere
Old Apr 20, 2006 | 06:42 AM
techbod's Avatar
there are 2 buttons on the lower part of the clocks, press and hold button B under the rev counter and turn the ignition on then release it, then while ignition is still on turn the other button A under the MPH to the left that will reset it, if its set to long life service nothing will happen and diagnostic reset tool will be required
Old May 11, 2006 | 07:58 PM
Audis42001's Avatar
will this work on a 2000 s4 >?<
Old May 11, 2006 | 08:02 PM
techbod's Avatar
yes
keep the button turned to the left till you see ( in 10.000 MI ) in the trip recorder display/odometer then turn the ignition off then its done
Old May 11, 2006 | 09:10 PM
Audis42001's Avatar
the thing i figured out was u have 2 hold both the buttons down then u can reset it i just did it it worked perfect thanks a lot
staglad
Mar 28, 2010 10:03 AM
jamesfreeman86
Dec 2, 2008 02:02 AM
Southern6er
Jun 1, 2008 09:06 PM
drake008
Jan 13, 2008 04:00 PM
dudley doright
Mar 14, 2005 02:18 PM
