Sport Trac Tire Pressure ? Under-steer and Stability Control
So the factory speck for 17" is 36psi front and 32psi rear.
So If I was to increase the Rear tire pressure I would effectively reduce the ideal contact patch and reduce rear traction. Has anyone played with rear tire pressure to try to dial out some of the under-steer and if so where did you end up? I was just wondering if you took the rears up to 36 what happened and if the car became a little bit more neutral. OR Has anyone tried any aftermarket sway bar, adjustable or fixed and how far does that get you to a neutral balance where when the tires start to break it is all 4 wheels at the same time ? Will stability control ever let you get there? |
RE: Sport Trac Tire Pressure ? Under-steer and Stability Control
ORIGINAL: wchp So the factory speck for 17" is 36psi front and 32psi rear. So If I was to increase the Rear tire pressure I would effectively reduce the ideal contact patch and reduce rear traction. Has anyone played with rear tire pressure to try to dial out some of the under-steer and if so where did you end up? I was just wondering if you took the rears up to 36 what happened and if the car became a little bit more neutral. OR Has anyone tried any aftermarket sway bar, adjustable or fixed and how far does that get you to a neutral balance where when the tires start to break it is all 4 wheels at the same time ? Will stability control ever let you get there? Isn't modding fun?:D Cheers! |
