Throttle/Pedal Position Sensor Issue
Old May 18, 2011 | 09:12 PM
kapattack's Avatar
Default Throttle/Pedal Position Sensor Issue
Code P0123 - Throttle/Pedal Position Sensor
I just bought a used Audi A3 Sportback 2006! I still am super excited about it but I am experiencing some issues.
I am getting the code P0123 from the computer which is Throttle/Pedal position sensor A Ckt High Input. If you have had this issue, can you help me diagnose this problem?
Here is some history. For the last couple of weeks I had codes P2293, P0171, and P0222 coming on intermittently but especially after I filled up with gas. A friend of mine thought the issue was the fuel filter and we replaced it today. (I can give some advice on this one if you need it) I cleared the codes and expected the issue to go away. It did not. The codes have cleared and not returned, but I have the new code P0123. I also still have the same symptoms indicating that the engine is not functioning properly.
Current symptoms: the power to the engine is not engaging when the gas pedal is pressed heavily.
My transmission seems to be okay because I can shift to all 6 gears in automatic, sport mode, and manual. As I start to drive my engine seems to be okay but as I continue to press down on the accelerator pedal I do not get an increase in power although I can hear my engine revving up. The rpms do not go above about 4000, but it sounds like they should be higher.
Any thoughts would be welcome.
spit144
Jan 7, 2025 12:39 PM
spit144
Oct 26, 2010 04:52 PM
ericrb76
Dec 2, 2008 06:20 PM
IshTerp
Oct 30, 2008 12:05 PM
brijan
Feb 15, 2008 08:48 PM
