What are my (lemon) options?
Hi gang,
(see this thread https://www.audiforums.com/m_639943/tm.htm for background)
So I've brought my A3 w/ 1500 miles into service again. 1st time was cracked cylinder head. Didn't start first time in the mornings. I got it back on Wednesday, and Thursday started fine in the morning. Friday morning: same issue. didn't start on the first try. Saturday morning (today) - same thing. Checked the coolant overflow reservoir and it was a bit below the level it was when I got it back on Wed. I also smelled the coolant and it has a gasoline smell in it. I compared with the loaner I just got and the loaner smells like regular coolant, not like gasoline.
I explained my concerns to the service gentleman, and he totally understood where I was coming from. I said:
1. If there's gas in the coolant, what's the long term effects? (service guy: "That's not good")
2. What if I ever want to sell this car? the buyer is going to check the service records, and run like heck. (service guy: "I totally understand")
3. I've got coolant in my engine cylinders and most likely the oil too. That can't be good. Is it rusting inside the cylinder when it sits overnight? The block is cast iron isn't it? Coolant is water based isn't it? There goes my rings and that perfect seal in the cylinder.
4. Does Audi want me driving a car with potential long term issues like this? Is that good for their name, and my safety?
5. I bought a precision engineered high performance German engineered vehicle. That's not what I got.
At what point can I request a new vehicle?
What would you do?
Have any of you gotten a lemon?
Very curious,
- J
What would you do?
Very curious,
- J
There is usually a substantial burden to meet before you can legally begin trying for a new car. A lot of it depends on what state you are in. Wikipedia has the government links for some states: http://en.wikipedia.org/wiki/Lemon_law. My understanding is that in most cases it has to be the same problem occurring multiple times. So if your cylinder head was cracked,repaired, cracked again, and was repaired again - you might be at the start of building a case.
You don't have a lot of choice other than going back to the dealer again. Are you in a metro area with more than one dealerwithin a reasonable distance? Take it to a different one if you are not happy with the message\service you are getting from your dealer. Ifthe dealer isn't able to fix it again, I would go to an independent Audi repair specialist andpaythe nominal charge for them totell you exactly what theissue is. Then go into the dealer telling them the problem and request for them to repair it.
I had an issue withan '89Jetta I owned that had several problems - including a cracked head. My dealer"couldn't find" any issues to repair. Meanwhile Ithought the car was barely drivable and impossible to start in the NJ winter. Idrove it off the VW lot, went across the street to theGoodyear shop, and paid them $25 totell me everything that was wrong. They did, Idroveback across the street30 minutes later with a laundry list ofissues,and Volkswagen made all of the repairs under waranty for me.In my case I think the technician looking at my car that day had no idea what he was doing.
If you're in the Atlanta metro area, I have been to the new Gwinnett Audi dealership and they were very customer focussed.
J,
I just completed a Lemon-Law return (not with my A3) on my wife's Cadillac SRX. As 'E' said, itvery much depends on the state you are in-- they all have different variations of the law. I'm in California, which is one of the most consumer-oriented. Even after meeting the required 4 service returns for the same problem, GM would not buy the car back, I was still not convinced they had resolved the issue. I contacted a Lemon-Law attorney, and they were very successful. I've returned the car and in accordance with California law at a very good deal, with zero attorney fees (In California, the car maker has to pay your attorney fees). Not only did I never enter a court, I never even met my lawyer face-to-face. I didn't read your history, but my suggestion is to do your homework, and keep the pressure up. Once you've met the requirement in your state, if Audi isn't working with you, find a lawyer. Don't depend on the dealer...they have no power. You need to contact Audi directly. Check the back of your owner's manual and make an official (mailed) complaint. Good luck.
Dilzman
Dilzman
Thank you both for your replies. I will do my homework and research the law here in Rhode Island. I'll wait to see what they find on Monday and hope for the best. If they end up fixing the problem, do you think it would be rude for me to ask for an extended warranty from Audi (100k) and/or free AudiCare service for my trouble and the obvious depreciation factor.
Thanks again, I'll keep you all posted.
- J
- J
Joseppe,
I'm in RI too and although I have never lemon-lawed a car a close friend of mine has lemond 2. An Oldsmobile about 10 years ago and a Honda van last year. It was not difficult and he didn't get a laywer involved. Just keep tight records of everything. When he was trying to get the Honda repaired they did offer him an extended warranty but the problem continued and he ended up with a new one.
Are you working with Inskip? if so I'm interested to here how this goes.
Good luck.
Good luck.
Hi Threshold,
Thanks for the info. Yes, I'm working with Inskip. They seem very professional and understand my concerns completely. I trust them so far and I'm not "freaking out" just yet. I just want to get what I paid for, not some frankenstein car with tons of repairs.
I really like the car, so I hope it all works out. I know every manufacturer isn't perfect and they occasionally make bad ones, so I understand and I'm pretty patient.
When your friend got the new van, did it cost him anything? Same model/year/options/color/etc?
I have an '07, and I doubt they'll be able to find an '07 w/ the same color and options. I hope I don't get screwed (if they give me a new one) and have to pay even more money for an '08.
Do you think it would make sense for them to give me a new one *before* it gets "lemon" status? For example: I "trade it in" for a new one at an even swap, and they take mine and fix it right, then use it as a loaner or something. That way the law doesn't become involved and the carfax doesn't show it's a lemon. When the sell it CPO, slap a 100k warranty on it and everyone's happy.
Should I suggest it?
Thanks,
- J
Thanks,
- J
ORIGINAL: threshold
Joseppe,
Good luck.
Joseppe,
Good luck.
My friend is on vacation in Canada this week but I'll shoot him an email to see if I can get some details. He ended up with a newer Honda van (lemoned a 96 and now has a 97 if I remember) but I don't know how the transaction worked.
I would think if it costs you a bit to get out of your problematic A3 and into a new, working great A3 it will be well woth it.
Josepee - here is the info my friend who has lemoned 2 cars sent me:
Here is the RI link to Lemon Law… you have to claim it under the law for the state in which you purchased. So even though I live in RI, I had to send a letter to Honda North America claiming under the Mass Lemon Law (Bought at Herb Chambers in Seekonk MA)
This is part is new to me:
http://www.dmv.org/ri-rhode-island/a...eased_Vehicles
http://www.dmv.org/ma-massachusetts/...eased_Vehicles
What I did:
- Know the lemon law
- Collect your receipts and document time lost from car
- Write a letter directly to the manufacturer (documents attached) and cite lemon law
My loss of time and inconvenience was my bartering for the replacement vehicle for a net cost of ZERO… don’t sign a thing unless there is a big fat zero in the “You pay amount”. Herb Chambers wanted a check for the outstanding amount to which a laughed at the finance manager – I told him I ain’t paying anything and not signing anything that doesn’t state I’m paying anything other than ZERO. The arbitrator was the one that the dealer is getting the check from, not you. The dealer just wanted it then and there and I was not having that BS… you dealers inconvenienced me, now you wait for the check. I plan on driving out today with my new vehicle.
This part of the RI law is new to me… I didn’t go throught the RI AG, I went directly to the Manufacturer. Funny thing it doesn’t list the Manufacturer’s list on the RI Lemon Law page any more. AG wants their friggin $20 –more red tape to delay. Here’s the list http://www.consumeraction.gov/carman.shtml
>> NEW TO ME
How to Proceed if You Own a New or Leased Vehicle
You must complete a complaint form with Rhode Island's Attorney General and pay a $20 filing fee. The Attorney General will then notify the manufacturer or dealer and then hand your case over to the Motor Vehicle Arbitration Board. The Board will gather and study all information relevant to your case before issuing a verdict.
If the verdict falls in your favor, the manufacturer or dealer who sold you your lemon will then have 30 days to comply to the terms decided by the Board. Uually, this means you'll either receive a full refund or an identical or similar replacement vehicle.
----------------Letter Template---------------------------------
<YOUR NAME>
<ADDRESS>
<PHONE> <DATE> <DEALER HQ (not your local dealer)>
<DEALER ADDRESS>
Dear Sir or Madam: I believe that my car is a "lemon" under the Massachusetts Lemon Law (Massachusetts General Laws; c. 90 Sec. 7N1/2). I am hereby making a written demand for relief under the Lemon Law and the Massachusetts Consumer Protection Act (Massachusetts General Laws, c. 93A, Sec.9). I purchased a 2006 Honda Odyssey EX-L on <DATE> from <DEALER> in <CITY/STATE>. The vehicle identification number or VIN number is <VIN>. Since I bought the vehicle, I have had to return it to the dealership a total of 4 times. My vehicle has been out of service for repairs for a total of 10 business days. My vehicle has been in Herb Chambers Honda for repairs on the following dates for repair of the following defects:
(Date in/out) (List problems complained of) 31 May / 31 May Creaking driver side slider door / rattling driver window
10 July / 10 July Oil leak, replaced oil pan gasket
12 July / 13 July Oil leak, replaced oil pan (claimed micro fracture in the pan)
15 July / 20 July Oil leak, replaced rear main seal and cover to the transmission
I am having the following problems with my vehicle at this time:
[/b]Persistent oil leak[/b]. We purchased Honda for reliability and peace of mind and solely for the arrival of our baby. The purchase of a Honda and primary reason in doing so was for the safety and reliability for our newborn child. The Honda name is known for it’s reliability and dependability and to this point that is hardly the case. Each time the Odyssey is brought in for service I have to unload all our baby’s things in the van (car seat, stroller, diaper bags, toys, CDs etc) and load them into a rental and vice versa when the van is ready for pickup. The unloading and loading, the oil stains on our cement driveway and stress from worrying; to say an inconvenience is a gross understatement.
These remaining defects substantially impair the use, market value or safety[/b] of my vehicle. I am hereby allowing you one final repair opportunity. If these repairs are not completed within seven business days of receipt of this letter, I am entitled to a replacement vehicle acceptable to me or a refund calculated in accordance with the Lemon Law.
Failure to comply with the Lemon Law is a violation of Massachusetts General Laws, c. 93A, and you may be subject to double or treble damages as well as attorney’s fees and court costs if this matter is taken to court. I look forward to hearing from you soon. Sincerely, <NAME>
What I did:
>> NEW TO ME
<YOUR NAME>
<ADDRESS>
<DEALER ADDRESS>
They saw the cold start problem today, but claim that there are no leaks in the cooling system (into the cylinders) from pressure testing it. Audi techline told them to go ahead and replace all four fuel injectors... which will be here on Wed or Thurs. Driving an A4 2.0T and not loving it as much as the A3. No way near as fun to drive. :-(
- J
- J
