winter tires
Old Jul 31, 2007 | 01:26 PM
tlchris's Avatar
Default winter tires
hi, i live in Quebec and own a A3 3.2 Quattro with 225-45-18 tires.
I want to buy new rims and winter tires for the winter, beside moving to Florida, what do you recommend that i buy.
Thanks
Christian
Old Jul 31, 2007 | 01:53 PM
AManCalledE's Avatar
Default RE: winter tires
Somebody else was asking about something similar the other day. Not sure if it was determined that 16" (5-112 lug pattern) will fit or not (haven't checked out the thread in several days), but 17" definitely will. Find some stealies and a good quality "winter tire", not an "all season". Blizzak's see to be the best known. A friend uses them on his 350z and they seem to work pretty well.
The smaller/skinnier you can go, the better.
Old Jul 31, 2007 | 02:07 PM
tlchris's Avatar
Thank you
Old Jul 31, 2007 | 02:39 PM
One other thing to consider, make sure that if you go with a smaller wheel, you go with a tire with a taller sidewall to keep the rolling diameter the same....I think Chef mentioned that tirerack.com had some kind of calculator.
Old Jul 31, 2007 | 07:43 PM
Jefferson's Avatar
Get the REAL winter tires. I've had Blizzaks and been very happy with them. (On an Acura Type-R for the winter)
Some winter tires are only siped, which helps, but not the total solution. You want tires with a winter compound that stays sticky in cold cold conditions. Also, get some winter wheels.of smaller rims.The tires are tremendously expensive at stock sizes for the Audi, and it would probably be even cheaper to buy the rims and tires for winter than to try and get a tire that fits your stock rims.
I plan on getting the Audi 16" winter wheels and some Blizzaks this winter.
Old Aug 1, 2007 | 08:44 AM
ericsherbrooke's Avatar
Hi there!!! I'm from quebec too (sherbrooke)!!! and I have 17 inches wheels for sale
man..what a coincidence!!!I have a set of 17 inches mag wheel with blizzack tires on them, i dont remember the size at this very moment.Wheels are in very good condition and tires are probably good for another winter (probly more since you have a quattro). I had them on my previous g35, Idont know yetifthe wheelwould fit on the a3 but i'm pretty sure the tire would (summer front wheel was 225/45 r18 ). I dont want them on the a3 becauseI ride on 17 inches and I want to go 16"
I want 16" because i'm cheap....
--> btw..I could check if the wheel fit on mine...bolt pattern + offset
Old Aug 1, 2007 | 11:31 AM
tlchris's Avatar
Hi Eric,
find out if they will fit my A3 and give me a price.
Thanks
Old Aug 1, 2007 | 11:46 AM
The wheels are stored away from home, I will check tire dimension to see if it work and then try to mount them directlyon the car, I will probably drive where they are this weekend.Will get back to you shortly, pls send me a PM with your e-mail adresse so I can send pics of the wheels and I hope picture of the tires threadthis weekend.
tar6day
Jan 5, 2012 01:19 PM
wpg2.0T
Oct 29, 2011 01:55 PM
pinkertonpunk
Jan 7, 2010 04:50 PM
ryanlucas13
May 12, 2009 11:15 PM
tonicboy
Apr 3, 2008 01:43 AM
