$240 and still rough idle and missfires ... advice please
went to a local shop i have had good luck with in the past ... first cleaned the MAF sensor ... fixed 1st prolem ... still rough idle though ... cleaned throttle body and new plugs and wires ... still rough idle ... sea foam treatment ( didn't put any in oil though ) ... and used a few different gass adatives .. still rough idle and miss fires.. brought back to local shop to read codes... miss fires & ran rich... one of my spark plug wires was not connected all the way ... all he did was push it in ... worked for a lil bit it seemed ... but now is still missfiring ? what else should i do ? haha ...
the dealer i bought it from put new plugs and wires when i got it... so i have no idea .... about 8 months ago ... i've been thinking about getting some diff plugs though .... just for fun
took the old plugs out put new set of NGK plug and drive it see if it makes any different even for a short time.
when I had boost leak, I was changing the plugs every day
it was running incrediable rich.
i have a free computer diagnositc i'm gonna have done here soon ... so i'll see what that brings up for codes ... for some reason i think its a coil pack though or somthing of that matter
yeah it will flucuate between 4-7 for an initial 2 sec then smooth out usally and the maybe move a lil bit again every so often if i let it idle ... often idleing will cause the check engine to start to blink ....
