$240 and still rough idle and missfires ... advice please
Old Mar 2, 2006 | 11:16 PM
brent07's Avatar
Default $240 and still rough idle and missfires ... advice please
went to a local shop i have had good luck with in the past ... first cleaned the MAF sensor ... fixed 1st prolem ... still rough idle though ... cleaned throttle body and new plugs and wires ... still rough idle ... sea foam treatment ( didn't put any in oil though ) ... and used a few different gass adatives .. still rough idle and miss fires.. brought back to local shop to read codes... miss fires & ran rich... one of my spark plug wires was not connected all the way ... all he did was push it in ... worked for a lil bit it seemed ... but now is still missfiring ? what else should i do ? haha ...
Old Mar 2, 2006 | 11:20 PM
aRIf's Avatar
Default RE: $240 and still rough idle and missfires ... advice please
everytime when I hear missfiring, I remember my boost leak problem
what did you plugs look like when you took them out?
Old Mar 2, 2006 | 11:21 PM
brent07's Avatar
the dealer i bought it from put new plugs and wires when i got it... so i have no idea .... about 8 months ago ... i've been thinking about getting some diff plugs though .... just for fun
Old Mar 2, 2006 | 11:39 PM
avanttripleloop's Avatar
do a compression test.
aRIf's Avatar
took the old plugs out put new set of NGK plug and drive it see if it makes any different even for a short time.
when I had boost leak, I was changing the plugs every day it was running incrediable rich.
Old Mar 2, 2006 | 11:44 PM
brent07's Avatar
i have a free computer diagnositc i'm gonna have done here soon ... so i'll see what that brings up for codes ... for some reason i think its a coil pack though or somthing of that matter
Old Mar 3, 2006 | 02:40 AM
Slowb5's Avatar
does the idle fluctuate?? what rpm's??
Old Mar 3, 2006 | 02:55 AM
brent07's Avatar
yeah it will flucuate between 4-7 for an initial 2 sec then smooth out usally and the maybe move a lil bit again every so often if i let it idle ... often idleing will cause the check engine to start to blink ....
Old Mar 3, 2006 | 02:58 AM
trailboss's Avatar
it would have to be a major boost leak to have a real rough idle. Could possably be your ICM.
Old Mar 3, 2006 | 03:17 AM
brent07's Avatar
i have a 2.8 30v not the 1.8t .... so no boosting to worry about
