[[Elim 2871R Dyno Result]]
ORIGINAL: Jeff
ya then you will get more power, try turning up the boost a bit more
ORIGINAL: liquidxit2
your running pretty rich on the midrange as compared to the rest of the curve. but a nice curve none the less
ORIGINAL: aRIf
Second Thumbnail Image shows it.
pretty broad curve. how much boost are you running? what about a/f ratios per rpm.
ORIGINAL: Jeff
if your not pulling timing then just try a bit more boost, im running 26psi daily and 30 when i wanna have fun on stock internals
yeah I made logs yesterday more than 30mins of driving include 1 CAPS run and all the timins are 0°
your timing should be a little higher then that. wow I didnt know you were running 44 psi in that case sell that turbo setup and get a new one. Im sorry if Im being rude but 44psi on an upgraded turbo shouldf put out a decent ammount of power. Over stock thats only 2.7 lbs of torque per psi. Feel free to bash and flame me and I wont mind.
yes 44.1 is fuel pressure not boost. Unitronic recommend to run 44.1 fuel pressure but mine is little higher than that, I think that's why I'm rich
