[[Elim 2871R Dyno Result]]
Old Mar 19, 2006 | 05:33 PM
  #51
liquidxit2's Avatar
Default RE: [[Elim 2871R Dyno Result]]
ORIGINAL: donsupreme
See that doesn't count. How can a company make a tune for 100 different cars, with different mods, climate, altitude and still be SAFE?
As a tuning company would you prefer to have numbers a little lower than a custom tune or a lot of power thats blows 3 in 10 engines?
Well its quite simple, the apr and giac tune for stage 1 have a boost setting and fuel map for a stock turbo at a set boost on the same motor. The tunning cant be outrageous, but more subtle . Its quite simple 1.8t 15psi 91 octane elevation will factor but with the tune they give its not super aggressive as youd think. If a car suffers from problems after a tune or flash its most likely an underlying issue that would have surfaced anyways.
Old Mar 19, 2006 | 06:30 PM
  #52
flyinb501's Avatar
As a tuning company would you prefer to have numbers a little lower than a custom tune or a lot of power thats blows 3 in 10 engines? I like REVO SPS3 because that allows some custom tuning based on factors such as octane in the tank, blah blah..
I agree. SPS 3 is awesome. That way when you get better gas and colder temps you can up the timing and boost, and vice versa.
290 whp on 91 is very good I think. With race gas, and some more timing and boost you should see much higher numbers.
Old Mar 19, 2006 | 08:08 PM
  #53
trailboss's Avatar
^^^ it was with race gas mixed in
Old Mar 19, 2006 | 09:28 PM
  #54
flyinb501's Avatar
ORIGINAL: trailboss
Alright, I see that now. But how much of a benefit can you see with race gas if the tuning is for 91? Probably not much.
Old Mar 19, 2006 | 11:10 PM
  #55
quattrosedan's Avatar
I agree there....
Old Mar 20, 2006 | 12:49 AM
  #56
Jeff's Avatar
Zombie Defense Force
i wanna see 300whp from your car
Old Mar 20, 2006 | 04:01 AM
  #57
aRIf's Avatar
ORIGINAL: Jeff
I hope we'll see it soon. I decrease the fp today and I'm still not getting any timing, i'm still very little rich. I logged about 30mins and only from a cyclinder 3 got like 1° ones and that's all, rest are 0°
ones I clear out the race gas, I'll get better logs I think. I dont understand others who got same setup like me pulling a lots of timing but not me.
*Race gas do make difference because I can turn the boost more without pulling huge timing issue, this is what Sean told me.
Old Mar 20, 2006 | 11:20 AM
  #58
GraffixWB's Avatar
are you using UNI??
Old Mar 20, 2006 | 11:58 AM
  #59
liquidxit2's Avatar
ORIGINAL: aRIf
ORIGINAL: Jeff
what boost are you running? try lowering the boost a little, I have found that that is the culprit of pulled ignition timing in most cases.
Old Mar 20, 2006 | 12:21 PM
  #60
aRIf's Avatar
ORIGINAL: GraffixWB
are you using UNI??
yes
