[Deleted]
Old Apr 26, 2004 | 01:36 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Apr 26, 2004 | 02:33 PM
brrman's Avatar
Default Engine Smoke
Possible coolant leak? Sometimes a hose may leak coolant onto the hot turbo/engine block/exhaust that gets burned off. Its smells distinct - like plastic burning or kinda sweet.
Old Apr 27, 2004 | 02:57 AM
1.8TQUATTRO's Avatar
The coolant is one possibility, but another is that if you changed or have had your oil changed recently there could have been some spill that poured on to a hot engine part when you went up the incline then burned off.
Old Apr 27, 2004 | 03:42 AM
brrman's Avatar
just how much smoke are we talkin about anyway? what color was it?
Old Apr 27, 2004 | 10:39 AM
Default [Deleted]
[Deleted by Admins]
Old Apr 27, 2004 | 04:49 PM
brrman's Avatar
typically white smoke = coolant, bluish smoke = oil and black smoke = fuel/gas.
Do you have any coolant leaking into the cabin (on the floorboards under the mats)? Could be a leaking Heater Core which would cause the smoke to enter through the AC vents. Check your coolant level.
There's also the possibility that you have a leaking seal on the turbo. When the oil leaks from that seal the combustion of the oil is total and the smoke will be white. This scenario will lead to a dead turbo eventually unless fixed.<edited><editID>brrman</editID><editDate>38104.5809722222</editDate></edited>
Old Apr 27, 2004 | 07:20 PM
SlimChriz's Avatar
It might be the blower fan if you had you pollen filter changed lately something might have fallen in there and when you went up the hill it got lodged between the fan and the case thefan is in...
Old Apr 27, 2004 | 07:22 PM
active1331's Avatar
<IMG src=smileys/smiley34.gif border="0">sound like coolant take it back to the dealer asap
Deleted User
Feb 27, 2004 08:42 PM
Deleted User
Jan 27, 2004 12:58 AM
Deleted User
Oct 23, 2003 03:37 PM
Deleted User
Sep 22, 2003 09:08 AM
Deleted User
Sep 21, 2003 02:30 PM
